Door Striker.
I sustained some damage to the hinge of the car. The hinge was removed. Repaired and reinforced and put back. Shut lovely. Now I suspect the door has dropped slightly again however I think the striker is masking the drop by lifting the door into position when its closed. I want to remove the striker so I can see if it is truly out of position. Also RD has given me the idea of repainting them whilst they are off too.
Just found out via another forum, good these forums, the striker plate is surrounded by a frame. By removing the two torx bolts it will, hopefully, just drop into that frame. So it should be safe to remove the two bolts without fear of it disappearing behind the B pillar.
Got to wait for the rain and high winds to stop now.
Thanks for the replies!
Jim's photo in post #4 shows the marks of a misaligned door on the striker (old one on the right). It can eventually cut a shiny groove into the striker where the lock is lifting (or dropping) the door over it to engage instead of the latch just being moved against the spring.
Authorized Trespasser
Nov 29, 2018 03:38 AM
