Drdsp door latch microswitch thread.
Old Feb 9, 2023 | 11:39 AM
Ant Buck's Avatar
Default Drdsp door latch microswitch thread.
Not being very computer savvy, i have been trying to find(without success) Drdsp's walk through on removing the door latch and replacing the door ajar microswitch. Is it just a case of going through the threads until i find it, or is there a quicker way. Many thanks.. Anthony.
Old Feb 9, 2023 | 12:03 PM
Johnken's Avatar
https://www.jaguarforums.com/forum/x...ch+replacement
Hope it helps Ant.
John
Old Feb 9, 2023 | 12:04 PM
Ant Buck's Avatar
Thank you.
Old Feb 9, 2023 | 12:24 PM
cjd777's Avatar
Here is another
https://www.jaguarforums.com/forum/x...solved-164147/
Old Feb 9, 2023 | 12:47 PM
Pistnbroke's Avatar
What exactly are you trying to do ...I can get the door lock out in about 6 min ...so what help do you need?>
Old Feb 10, 2023 | 10:39 AM
Ant Buck's Avatar
The drivers window will drop to open the door ,but will not return when the door is closed and the door open message is lit, so i was going to change the microswitch and see if that cures the problem.
Old Mar 14, 2023 | 12:14 PM
Ant Buck's Avatar
Finally got around to changing the microswitch on the drivers door, all is well and functioning. The original switch looked like it had suffered from water ingress. The job probably took a couple of hours, not difficult to do just fiddly. Really pleased with the result. Thanks for the info.
dmax7
Aug 13, 2022 11:34 PM
Reverend Sam
Jul 29, 2019 05:18 PM
pingj
Oct 14, 2011 04:50 PM
FloridaXJR
Jul 20, 2011 09:33 AM
Drdee
Dec 29, 2010 06:50 PM
