Dreaded engine failsafe mode
Old Mar 15, 2018 | 06:12 PM
Gregfromuk's Avatar
Default Dreaded engine failsafe mode
Car wont start, although it did start 4 times on the trot and drove fine but then nothing.
I had no codes, so I checked fuel pressure, changed the crankshaft sensor and the spark plugs. I then got a P1229 code, so today I replaced the throttle body. I have no codes anymore but it is still in failsafe engine mode. Also put a teaspoon of oil down the barrels in case it had bore wash.
My question is ladies and gentlemen... should I now be looking at the ECU?
I thank you lol
Old Mar 15, 2018 | 06:28 PM
JBzXJ40's Avatar
Is it starting now or still no start?
Any other symptoms? Do you have fuel pressure, spark?
Any other codes logged?
Old Mar 15, 2018 | 06:33 PM
Gregfromuk's Avatar
I have fuel pressure I don't have spark when engine failsafe mode comes up but it will randomly disappear and the car will start but as I said, it has come back now and no start :-(
No codes now either
Old Mar 15, 2018 | 07:56 PM
JBzXJ40's Avatar
Interesting
A tech I used to work next to had a similar issue. It was running when it came in, just for a service, then after it wouldn't start. Turned out the issue was inside the ECU, problem on ignition circuits.
I don't know about UK - but I would assume there is someone there who repairs ECU's. It's just a matter of taking it out and finding someone who can have a look.
Someone from UK here might be able to chime in - worth having it checked.
Old Mar 15, 2018 | 09:12 PM
NBCat's Avatar
Have you checked all the loom connections and battery voltage? Should be a minimum of 12.6 volts across the terminals with the ignition in the OFF position for ten minutes.
Old Mar 15, 2018 | 09:47 PM
zray's Avatar
What condition is your battery in ? Have you had it tested with a load on it ?
my battery was on its last legs, and I got the failsafe mode warning, wouldn't start, etc. all kinds of non functional on the dash, the CD player , the navigation screen, etc I replaced the battery and not a single hiccup so far. Thiese cars are very sensitive in regsrds to battery voltage and battery strength.
z
Old Mar 15, 2018 | 10:05 PM
Ungn's Avatar
Its turning over on the battery but not starting?
I've got a failsafe warning when my alternator died and I ran on the battery for 17 miles around the time the dash gage said 9 volts (but who knows how much voltage the battery actually had).
Old Mar 16, 2018 | 02:28 AM
JagV8's Avatar
Could it be bore wash?
If it spins but doesn't start then... maybe.
Old Mar 16, 2018 | 03:50 AM
Gregfromuk's Avatar
It's not bore wash, as I said in my first post I oiled the barrels. It will randomly start and run completely normaly even if the engine failsafe pops up on the dash but if i turn it off with the engine failsafeon the dash it will not start again. The RAC guy put a new battery on it and it still wouldn't start. I also have a new battery on it now.
I checked all the loom conections, everything is clean. I'm thinking ECU?
Old Mar 16, 2018 | 03:54 AM
Originally Posted by Gregfromuk
..... I then got a P1229 code, so today I replaced the throttle body. I have no codes anymore but it is still in failsafe engine mode. .....
Code P1229 possible causes are:
1. Throttle motor disconnected
2. Throttle motor to ECM drive circuits short circuit or open circuit
3. Throttle motor failure
You've gone direct to (3) which should therefore also have eliminated (1). ECM faults are rare - harness and connector faults are much more common.
Still being in failsafe mode must have associated code(s) .....
Old Mar 16, 2018 | 04:15 AM
Gregfromuk's Avatar
I checked the wiring,everything is clean. Unbolted the main conector behind the throttle, everything is clean and shiny in there too. I (unfortunately) no longer have any codes.
IO guess it can't do any harm having a look at the ecu?
Old Mar 16, 2018 | 06:18 AM
RJ237's Avatar
JagV8 mentioned bore wash. It wouldn't take a lot of work to pull the plugs and do a compression check.
Old Mar 16, 2018 | 07:17 AM
JagV8's Avatar
He says he did. However by now it may be like that and it's worth looking (again).
If codes were cleared then also all the OBD monitors were cleared. Any that have not yet set again may be causing the car to be unable to flag codes. And also unable to set the monitor(s) - Catch-22.
(It's why clearing codes is not really a good idea.)
Old Mar 16, 2018 | 07:25 AM
fmertz's Avatar
Have you checked the operation of the throttle body? If you pull the intake tube and put the ignition on (engine off), you should be able to see the butterfly move as you press the gas pedal.
From memory, there is a throttle body programming procedure. I have not had to deal with this, so I am unsure. You can always do the basic procedure: ignition on, engine off, slowly press the gas pedal through it's entire range, including the kickdown switch if you have one, then back off. Do this a few times to "teach" the ECU about the range of the pedal sensor. Free procedure, nothing to lose.
The proper path is to try and locate a Jaguar-aware scan tool and see if there is anything stored. For no-start conditions, I believe the ECU stores live data that can be read with OBD software.
Best of luck, keep us posted.
Old Mar 16, 2018 | 08:14 AM
Gregfromuk's Avatar
Thanks guys. The thing is, I have already done everything that you have all said. I also did the proper procedure for a new throttle body (pedal slowly down etc) I’ve spent hours on here reading other people’s posts. Starting off with the small things. It started the other day completely normally l, I tookk it for a 20 min drive no problems at all. I switched it off and left it to heat soak for a while but when I went to start it, low and behold failsafe engine mode !
Old Mar 16, 2018 | 09:49 AM
dibbit's Avatar
Given the age of the car and the things you have already tried, I think it would be sensible to have a look at the ECU to check for blown capacitors. First though you might want to do what fmertz has suggested and see if you can read any live data that might give you a clue when it is failing to start.
Old Mar 16, 2018 | 04:04 PM
Gus's Avatar
Gus
Turn the key on for 10 to 20 seconds then attempt to start the car do it in “P” & “N” and see what takes place.
Old Mar 17, 2018 | 12:49 AM
zray's Avatar
i love these tips. What does this procedure reveal ?
z
Old Mar 17, 2018 | 08:55 AM
Gus's Avatar
Gus
I am not sure at the moment because I am experiencing the same issue. I am at the point that I feel it is the ECM but want to do additional testing. With my situation I could turn the key on for about 20 seconds and then start it and it would start. The attached video will show you how I am not getting spark on the start action but after a few seconds on the second start it starts up.
Old Mar 17, 2018 | 10:44 AM
USCANAM's Avatar
Default Relay connections.
Remove and clean all under the hood(bonnet) connections.
One Day on our 2003 XK8 car was perfect. Stopped to eat, car started and went into limp mode.
Checked codes when limped home. Throttle body. Finally found relay had popped out of its socket???
Dont know why, but it did.
Might be a similar relay problem for you.
