Driver door panel loose '99 XK8 conv.
Old May 4, 2012 | 08:11 PM
midamdoc's Avatar
Default Driver door panel loose '99 XK8 conv.
Driver door panel on 1999 XK8 is loose falling inward; appears to be a broken yellow U shaped connector and black plastic pin like connectors that came out. Any suggestions on self repair or obtaining the connectors?
Old May 4, 2012 | 08:47 PM
WhiteXKR's Avatar
The U-shaped brackets usually can be repaired with JB-Weld (regular, NOT QUIK SET).
If it is too damaged and you need to replace the part number for the upper rear one is C2N3837, which is the most common one to break and there is a factory bulletin on. It woiud need to be fastened with epoxy or strong hot-melt glue.
Jaguar Parts - Direct JPLV Porsche Parts.com
The pin fasteners are part number KTC100017
If any receptacles in the door are also broken they are KZV100010
Next time please visit us in the XK8/XKR section...not general tech help...you will find lots more help and cameraderie there.
File Type: pdf
99xk8guy
Sep 29, 2025 10:51 PM
GordoCatCar
Jan 2, 2017 01:10 PM
AL NZ
Sep 4, 2015 08:39 PM
philwarner
Sep 3, 2015 10:14 PM
obwoodie
Sep 3, 2015 07:45 PM
