Driver Side Seatbelt is Loose
Old Jan 27, 2013 | 02:40 PM
artstar's Avatar
Default Driver Side Seatbelt is Loose
I've had the problem for a while just never thought about fixing it since it doesn't really effect the operation of the belt until I take it off and it doesn't retract. Anyone had any experience with this and fixing it?
Old Jan 27, 2013 | 02:54 PM
Provided the Retraction Spring (item 2) isn't broken, the belt could either be twisted or not wound evenly causing it to stick.
Try pulling it out to the full extent and feeding back in. If it's twisted, you'll probably have to remove the pillar trim to straighten it out.
If the Retraction Spring is broken, it's bad news. There's no serviceable parts in the belt.
Old Jan 28, 2013 | 12:06 PM
H20boy's Avatar
+1 agree w/ Graham, its easy to get twisted.
Old Jan 28, 2013 | 02:46 PM
Estilian's Avatar
I have the same problem and I've already tried to pull it all way out and then put it back... unfortunately - no luck with that.
Having in mind that the "force" of retraction of my seat belt seems to be relative to the air temperature in the car (when it's cold it doesn't even move, when it's hot - it needs just a little push to spin back) the reason should be the spring (based on the image it's the element №2) and maybe it's not broken but just loosened.
So the question is - is it possible to "renew" the spring or maybe replace it with another one, even from another car? Or if the spring in the front seat belts and those from the rear seat are the same - maybe it's possible to switch them?
Old Jan 28, 2013 | 09:00 PM
artstar's Avatar
Pulling it all the way out helped it, it's not a spring problem it's just that the spring seems to not be strong enough to pull it all the way in. So I have to help it most of the time to get back in, not very attractive but I guess it's better than the alternative which I'm not even sure there is one.
Old Jan 28, 2013 | 09:27 PM
Kevin D's Avatar
I suspect that the spring just weakens over time. Mine is not to the point where it won't retract, but I have to make sure that it lines up before it will pull itself in. I actually sprayed some Armor All on the belt down toward the end where it winds in and that little bit of slipperiness helped it to retract a good bit better.
Old Jan 29, 2013 | 07:52 AM
Originally Posted by Estilian
.............. So the question is - is it possible to "renew" the spring or maybe replace it with another one, even from another car? Or if the spring in the front seat belts and those from the rear seat are the same - maybe it's possible to switch them?
I don't usually post information on procedures which are potentially dangerous but this thread has raised the question of dismantling seat belts. Anyone considering even removing them needs to be aware of the risks and safe handling procedure.
I'd not even consider dismantling a seat belt in an attempt to replace the spring. The assembly has a pyrotechnic pre-tensioner.
This extract from JTIS should act as a warning:
Each front seat belt has a pyrotechnic device with independent mechanical sensing and pre-tensioning retractor unit, installed at the base of the 'B' post. In the event of severe frontal impact, this provides additional occupant protection by removing any excess slack from the seat belt. Seat belt pre-tensioning activates when a frontal impact of sufficient force occurs within 30 degrees of vehicle center line. Under such an impact, mechanical sensors in the retractor unit fire, igniting the pre-tensioner gas generator. The gas generator initiates a chemical reaction, producing gases under pressure. Gas pressure drives the piston/cable up a tube, rotating the retractor spindle and removing excess slack from the seat belt. The mechanical sensor is made live by screwing the arming pin in to fully depress the red arming button.
The pre-tensioning system can only be activated if a safety lever is re-set by fitting the associated belt to an occupant or child seat. When the pre-tensioner unit has been activated, the seat belt will lock and cannot be retracted or pulled from the reel.
No attempt must be made to dismantle a retractor unit as unactivated pre-tensioning components contain a solid, flammable material. There are no serviceable parts. If a pre-tensioning unit is inadvertently ruptured and ingestion or inhalation of the propellant occurs, first aid must be applied and medical advice sought.
When handling the piston housing, the piston must be pointed downwards and away from one's self and other personnel. Fingers must be kept away from the take-up spool mechanism.
Any unit dropped from a height greater than 0.3 m (12 inches) must not be fitted to a vehicle.
If a seat belt pre-tensioner activates, a small quantity (less than 1 liter) of gas is produced containing nitrogen, oxygen and water vapor.
The safest solution is to fit a replacement seat belt but one option for those with a 'lazy' Driver's seat belt which retracts slowly or needs a bit of help is to switch Driver's and Passenger's seat belts. These are not handed on the XK8 - LH side and RH side are the same.
Here is the removal and refitting procedure:
JTIS - XK8 Front Seat Belt Removal & Refitting.pdf
Note section 9 on page 3 regarding the pre-tensioner arming bolt. If the pre-tensioner fires, the retractor spindle rotates very quickly.
Old Jan 29, 2013 | 09:50 AM
dennisw's Avatar
I asked this question about a year ago and Sam was going to look into it..the return spring has lost its power..you should not have to feed it back in.there must be a way to fix it.
02jagstype
23
Oct 23, 2022 07:03 PM
kevinl
Oct 31, 2019 06:15 PM
mbergen
Oct 23, 2019 10:26 PM
Dicque
Sep 19, 2015 12:53 PM
avern1
Sep 8, 2015 06:25 PM
