Driver's door on convertible stopped lowering glass automatically, please help!
Old Apr 2, 2011 | 08:56 PM
Mish_Mish's Avatar
Default Driver's door on convertible stopped lowering glass automatically, please help!
I just drove my XKR and it seemd normal, however when I came home, driver's side door glass stopped doing automatic dive, when opened and closed. Obviously it is now impossible to close the door, unless glass is rolled down a pinch.
I checked passenger door and it works normal.
What do I check, please help, oh mighty jaguar gods!
Old Apr 2, 2011 | 09:25 PM
test point's Avatar
This is sorta like joke #47.
The most likely solution is to reset the upper/lower limits memory. Most likely cause is low battery voltage.
Old Apr 2, 2011 | 09:30 PM
Mish_Mish's Avatar
And to reset those I have to do what exactly?
Is there some secret e-clitoris, I need to wiggle?
Old Apr 2, 2011 | 09:42 PM
WhiteXKR's Avatar
Lower the window and do not let go of the down button untill you hear a faint click. Then raise the window and do not let go of the button until you hear a faint click. Done.
Old Apr 2, 2011 | 10:08 PM
Mish_Mish's Avatar
Thumbs down
IT WORKED!!! After two attempts (first it worked down, but not up), it came back to normal.
Thank you!
This car is like box of chocolates, you never know what's not going to work next
Old Apr 3, 2011 | 02:46 AM
H20boy's Avatar
And if you ever notice, that when you pull the door handle up, the glass goes down, and if you release the door handle...the glass should stay down until you shut the door. If it returns immediately after releasing the handle, the switch in the door handle is at fault...requires a new latch, or remove the old switch for a repair...which only a couple have managed to do. Just keep that in mind.
Old Apr 3, 2011 | 09:53 AM
Reverend Sam's Avatar
I made a video of that, I just cant find it! I hope I didn't delete it.
Found them! I'll put together the pieces into a video and upload it this evening. My wife and I are about to take the convertible to the beach!
Old Apr 3, 2011 | 07:17 PM
hlgeorge's Avatar
Thank you!
This is where reading the owner's manual really helps!!
Old Apr 3, 2011 | 09:21 PM
LOL! I already posted the door latch video right here. My memory sucks.
BrentGardner
29
Dec 16, 2024 12:13 AM
rvdz
Dec 7, 2019 06:42 AM
Khan
Aug 30, 2015 10:13 AM
Jandreu
Aug 29, 2015 07:31 PM
divingmom
Aug 25, 2015 07:54 PM
