Driver's Door Open Indication
Old Oct 11, 2012 | 08:59 AM
scardini1's Avatar
Default Driver's Door Open Indication
Hi Guys!
I have a "Driver's Door Open" indication that won't go out. Of course, because of that the doors won't lock while driving and the window doesn't go up the extra little bit when I get in and close the door.
Sound familiar to anyone?
I can't see where the door-closed signal would come from, unless it's that rubber plug on the sill just above the the lock catch.
Thanks in advance!
Jim M.
Old Oct 11, 2012 | 09:22 AM
Paul Pavlik's Avatar
Originally Posted by scardini1
Hi Guys!
Thanks in advance!
Jim M.
The "Door Closed" Switch is located in the Latch/Lock Assembly inside of the Door. The Micro Switch is one of several switches on the assembly and is a known failure item.
To access the Latch/Lock Assembly, the Door panel must be removed.
Old Oct 11, 2012 | 11:10 AM
scardini1's Avatar
Thanks Paul,
I just watched the respective videos - shouldn't be too hard a job once I get a new latch. It does seem as if the "Market" has responded to the video as well - the $10 eBay latch he bought for the video is now well over $100 used! Has anyone ever tried to replace the micro switch itself (ala Radio Shack)?
BTW: Is there a difference between pre and post '03 latches? Some of the eBay sellers are listing them as "'97 to '02". Can I use one of those?
Old Oct 11, 2012 | 11:12 AM
scardini1's Avatar
I also thought "this" was strange: My interior lights are "not" on despite the car thinking that the door is open. Is that controled by a different switch?
Thanks!
Old Oct 12, 2012 | 02:01 PM
scardini1's Avatar
Does anyone in the SOMD area have a bad door latch I could steal? I think I'd like to "play" with one before I go in to replace it.
Just send me an message or post here.
Thanks!
Old Oct 12, 2012 | 03:47 PM
H20boy's Avatar
send Gus a PM, he's already dissected one of those...IIRC. If anyone can give you hope of finding another source for them, he will let you know.
Old Oct 12, 2012 | 04:32 PM
Beav's Avatar
britishparts.co.uk lists at least one of the three switches
Old Oct 12, 2012 | 05:00 PM
Gus's Avatar
Gus
Do yourself a favor and hold off on pulling the door apart. Take a little WD40 and spray it into the door latch mechanism and work the door a few times. Yes the door has a few micro switches and they can be replaced but not using RadioShack. I will provide a link showing the door latch and the micro switches, I will also provide a link for correct replacement switches if you need them.
Link D2SW-3L3MS Omron Electronics | Mouser
Try the WD40 first many of the problem with the door latches are related to the lack of lubrication and corrosion and not a failed micro switch. However, it is possible.
Old Oct 13, 2012 | 11:36 AM
scardini1's Avatar
Default Thanks!
OUTSTANDING! You guys are great. Now this is the of help "any" auto community needs for it's enthusiasts. I'll try the WD/PB starting tonight and give it a few days to take effect. I'll be back with the results. Having alternative sources for the latches and switches is a real help.
THANKS!
Jim M
Old Oct 15, 2012 | 04:42 PM
scardini1's Avatar
Default Much Better!
Thanks guys. The WD did the trick (for now). Someday, when I'm in an especially masochistic mood ( ), I might go into the doors and do some preventative work based on various forum discussions.
THANKS AGAIN! - Jim M.
Old Oct 15, 2012 | 07:06 PM
Gus's Avatar
Gus
Kudos to you! On the road again.
Old Oct 15, 2012 | 11:45 PM
Steve8's Avatar
Kudos to Scardini for making the fix. Kudos also to Gus for suggesting the obvious! I may go spray some on my doors just as a preventative step.
Steve
Old Feb 8, 2013 | 03:38 AM
Asw48's Avatar
Thank you all. I have this same problem today because for the last week, each day my car is under 6 inches of snow. Rather than take anything apart I will now manipulate the door handle and latch mechanism when the temperature increases a little.
Great Forum...Thanks Guys.
Old Feb 8, 2013 | 03:41 AM
steveinfrance's Avatar
If you look in the HOW-TOs there's a thread including replacement of the switch and various sources for it (about $10)
99xk8guy
Sep 29, 2025 10:51 PM
VinnyT
72
Sep 28, 2025 12:17 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
philwarner
Sep 3, 2015 10:14 PM
