Drivers door switch not operating passenger window
Old May 17, 2018 | 12:52 PM
Barry_Tucker's Avatar
Default Drivers door switch not operating passenger window
I am finishing up winter maintenance. I just replaced the 'door ajar' micro switch on the drivers (NA) door, and the driver's door switch pack ( the mirror switch was buggered ) . I tested things numerous times during the whole process and quite suddenly the drivers door switch will no longer operate the passenger window. I tried the old switch again and it won't operate the passenger window either . Both switches operate the drivers window perfectly and the passenger window works fine from the passenger door. This is not a huge issue but is a bit of a nuisance.
Do any of you knowledgeable folks have any insight on what it might be ?
Old May 17, 2018 | 01:14 PM
smoggyx100's Avatar
This can happen when working on the doors and unplugging switches.
Try a hard reset, disconnect battery earh lead for 10 mins then reconnect.
that usually resets it.
Old May 17, 2018 | 03:38 PM
Thanks ...that sorted it
PeterXJ8
20
Apr 2, 2026 07:28 AM
JimJam
Sep 12, 2016 06:58 PM
K10MRG
Sep 1, 2014 12:34 PM
CJNetrider
Mar 2, 2012 08:56 AM
missmaryquinn
Dec 16, 2008 07:29 AM
