Drivers Light Keeps Turning Off
Old Jul 3, 2016 | 08:50 PM
rhemler's Avatar
Question Drivers Light Keeps Turning Off
Hello everyone,
I'm having a weird issues with my headlights (or headlight I should say). When the car is on the driver's side headlight won't turn on, the parking light is on but not the hid, at first I thought the bulb was just out, but I tried hitting the lights on button on the key fob, and both lights come on without issue, so I got back in the car to test it and found that both builds work fine and well when I only turn the battery on, the minute I turn the key over the driver's side bulb shuts off. I tried searching around the forums for a similar post but haven't found anything, any advice?
Old Jul 3, 2016 | 11:37 PM
rhemler's Avatar
And now I feel I should add the light now does not work - and I hear this hissing sound - the lights to appear to level normally.
Old Jul 4, 2016 | 02:45 AM
If the bulb is OK, then the combined Ballast/Headlamp Leveling Module must be suspect.
Before throwing money at it, you could swap modules left to right to see if the fault then also moves to the other side.
Old Jul 5, 2016 | 11:54 AM
rhemler's Avatar
Checked the lights as you said switched them around - I was able to determine the problem lies with the ballast, thanks for the tip!
Ryan
LnrB
Apr 13, 2016 10:23 PM
joolz
Apr 10, 2016 02:01 PM
geewilicurs
Apr 5, 2016 06:37 PM
Oct 4, 2006 12:42 AM
