Driver's side window problem
Old Jan 14, 2013 | 11:52 AM
giandanielxk8's Avatar
Default Driver's side window problem
I never got around to solving this problem. So here's a quick explanation:
My driver's side window must have a loose bolt or something. The problem is that the window won't lower or rise on command. It's not an electrical problem, since I can hear a faint click when I press on the button. It's also not the motor or the regulator since if I bang on the inside of the door hard enough the window will obey my commands. It'l lower and raise, but slowly and at a certain point it seems to change position and move a little faster. If I raise it again and then leave it alone it will stop obeying, so to speak. It's almost as if there is something in the way. I'm thinking that maybe I should perform a window adjustment, but is there anything else to check?
PS. It's not the dying battery indicator. The window doesn't move at all when I open the door, whereas the passenger door and window work correctly.
Old Jan 14, 2013 | 04:13 PM
I managed to fix it. After removing the door trim and diving ahead and removing unnecessary screws I was able to identify the problem. There was a disconnected power cable for the motor. After connecting that I had to reseat the glass and connect everything again.
I did notice, however, that I might have done a tiny error with the window adjustments. The window doesn't go all the way up. It stops a couple millimeters shy of where it should and when I open the door it drops a few more than it should, but as long as no water gets in, I can live with a little wind noise.
Old Jan 14, 2013 | 05:56 PM
ccfulton's Avatar
The window has a regulator stop adjustment that you can set higher or lower as a reference for the window drop. With the door panel and the interior plastic liner off you can see a large torx bolt on the regulator near the center of the door. It is behind the clear plastic water shedder and you will need to cut a small slit in it to access the bolt.
It's a bolt on a slide and by adjusting it toward the rear of the car you can set the max window height higher.
Sorry I don't have JTIS handy to post the procedure.
Old Jan 14, 2013 | 06:05 PM
ccfulton's Avatar
The procedure is posted as images in this thread: https://www.jaguarforums.com/forum/x...26/#post207913
It's a ridiculously complicated procedure to adjust the windows if you do the whole thing, but the bit you need is on p4 and 5, which isn't too bad.
Old Jan 14, 2013 | 09:59 PM
Damn... Yeah, I remember the bolt, I actually fiddled with it. I'll get to that eventually.
toronadomike
Jan 22, 2026 10:13 PM
alpecsa
Sep 7, 2015 11:55 AM
tberg
Sep 7, 2015 07:32 AM
tberg
Aug 31, 2015 04:33 PM
Khan
Aug 30, 2015 10:13 AM
