Driveshaft installation questions 97 xk8
Hi,does anyone have a video on how to replace the upper driveshaft? I have the factory instructions but I've never done one so I would like to see it done or pictures of it. Also should I buy one and have it rebuilt? Or is it not necessary? All this because the rod that connects the lock cylinder to the starter switch behind it wont engage, got a new cylinder out it in now key turns but I cant get it into position so the cylinder is stuck. Any info about lock cylinder or driveshaft install is appreciated. Thanks in advance. Mike
Mike,
157 Views but 0 Replies.
I'm used to much of the different vehicle terminology between UK and US but didn't think driveshaft was one of them. Isn't upper steering column also used in the US for the part you describe? If so, you are more likely to get Replies if I change the thread title for you.
GerryXJR
Apr 5, 2013 04:18 AM
Walter1982
Jun 2, 2009 10:35 PM
