A drum again
Old Aug 30, 2016 | 05:24 PM
dsnyder586's Avatar
Default A drum again
OK,
bought another car with a transmission issue. I have two in the garage that I had planned to fix and now is the time I guess. One had about 79K on the clock and good looking clutch plates, the other has about $130 and the plates are still good, but more worn than the other. My plan is to replace the A drum with a reinforced one along with the valve on the other and keep it for a quick swap if any of mine go bad.
I ordered a reinforced A drum and the pressure valve upgrade- has anyone done this? Can I just remove the part of the valve body that has the valve, or do I need to remove the whole valve body to replace?
Thanks!
Old Aug 30, 2016 | 07:25 PM
RJ237's Avatar
Just the forward valve body. With the valve body on the bench I used a couple of bar clamps to hold the cover plate in place while removing the screws. The same to reassemble.
Old Sep 6, 2016 | 11:08 AM
dsnyder586's Avatar
Good news- The A drum fractured but never broke on the trans that was in the car so.... Looks like a straight forward swap, valve and install! I'll rebuild one of the others bottom up so I have a good used spare.
Old Sep 8, 2016 | 05:33 PM
dsnyder586's Avatar
To wrap this up- I replaced the valve and A drum, filled it at 30 degrees C and it is running like a top- took it around the block and on the freeway.
Interesting thing though- it is very tame in regular but in sport the car turns into a beast. Much more noticeable difference than my convertible of the same year.
BobRoy
49
Sep 18, 2016 10:48 AM
Catsgame
Mar 30, 2016 01:05 PM
JJHouston
Mar 26, 2016 12:23 PM
Jan 3, 2007 09:07 PM
