DSC Fault
Old May 19, 2010 | 09:26 AM
Arkwright's Avatar
Default DSC Fault
Hi,
Can any one tell me what DSC SYSTEM FAULT means
This only comes on every now & then do i need to do some thing about it
usally comes on with the abs light
Old May 25, 2010 | 09:34 PM
Reverend Sam's Avatar
That's so weird! I got the same exact problem today. I just bought the car yesterday, and today the DSC fault and ABS light came on at the same time. I stopped the car and restarted the engine and the lights went out, but I noticed that under medium braking I could hear the ABS chattering even though I was on dry pavement. I washed the car and scrubbed the wheels shortly before the lights came on, so I'm wondering if one of the wheel speed sensors is going bad, or maybe one of the electrical connections is wet.
I have a 2003 XK8, by the way.
Old May 25, 2010 | 09:42 PM
DaleD's Avatar
From: Marin County, CA, USA - Just north of San Francisco
Me too - especially when I go into a twisty driveway from the street with my foot of the brake pedal. Warning lights seem to do nothing - and go away with a restart. Any suggestions? Clean connections on the wheels? DaleD99
Old May 25, 2010 | 10:13 PM
H20boy's Avatar
The first thing to do is to remove each wheel speed sensor from the hub assembly and give it a good soapy dawn scrubbin. If you had access to a scanner, like the AutoEngenuity w/ enhanced features enabled, the code could tell you EXACTLY which corner is having the issue.
If after cleaning, all remains the same (and you get some messages) look at the wiring harnesses next. (see how knowing which corner would be quite helpful?) then you could swap sensors around. If you know its the LF corner with the problem, and you swap with the RF, and the codes move over there, then its obviously the sensor.
Its a progressive diagnostic, but you can nail it down.
Dale D, sent you a PM with a little assistance.
Old May 25, 2010 | 10:40 PM
DaleD's Avatar
Thanks Matt - reply posted. DaleD
Old May 26, 2010 | 03:12 AM
Arkwright's Avatar
Thanks for the info,
I`ll give them a dame good scrub at the weekend
Old May 26, 2010 | 10:32 AM
H20boy's Avatar
When I first got my car from the jag dealer, I got a couple intermittent messages also, and after cleaning them really well, they went away permanently. Jag brake pads are very dusty (which I tend to believe was the cause of the sensor issue) and I changed them as well afterward to aftermarket pads.
good luck, and please let us know how it goes!
JaguarLover101
48
Jun 12, 2023 10:28 AM
radiatn
Jul 2, 2021 04:45 PM
goges
Oct 5, 2015 04:53 PM
3lvis
Oct 1, 2015 01:56 PM
