DTC P1797 but still running fine
Old May 19, 2010 | 07:47 PM
bigbandwith's Avatar
Default DTC P1797 but still running fine
I have a 97 XK8 133k miles. Throwing DTC 1797 but still runs/shifts fine.
Is this a sign of impending tranny, ECM, or TCM failure?
Thanks.
Old May 19, 2010 | 08:41 PM
test point's Avatar
P1797 is a code for the CANetwork. It is not even listed in the JTIS charts.
Any other codes?
Indicating ECM/TCM/Network failure.
First guess is a bad connection. Continuous? Occasionally? Perhaps start with disconnecting/reconnecting the ECM/TCM connectors with a little electronic spray on them.
Early throttle bodies have a history of electrical problems. Disconnect/spray/reconnect.
Old May 19, 2010 | 08:49 PM
Default other codes...
The car is also throwing other codes but they all seem a bit easier to diagnose/fix.
P0174
P0171
P0441
Most of the info I found on p1797 dealt with "limp home mode" and failing transmissions. Keeping my fingers crossed it is not serious.
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
Xkr x100
Sep 6, 2015 08:50 AM
Dymaxxion
Sep 4, 2015 02:40 PM
