DYI throttle body
Old May 11, 2020 | 05:59 PM
98 shadow's Avatar
Default DYI throttle body
I have a 2001 XKR and this long weekend am going to try changing my throttle body (just bought a new one) does any one out there know a video I can watch and any problems to stay clear of
Old May 11, 2020 | 07:43 PM
giandanielxk8's Avatar
If it’s only the throttle body and not the elbow as well, then it’s a very easy job. Once you have removed the intake pipe there are:
  • two coolant hoses you have to remove
  • 1 or 2 vacuum lines
  • 3 electrical connections
  • 4 screws. I can’t recall if those are torx, 10 mm or 8 mm
  • 1 metal gasket between it and the elbow.
Removing the elbow is a lot more tedious as you have to deal with the EGR pipe, the rubber gasket sandwiched between it and the supercharger (which is quite a bear to get aligned) and the screws for that, the two charge cooler to weird Y-pipe hoses, the part load breather pipe, a couple more coolant hoses. That’s already half the work of removing the supercharger.
Old May 12, 2020 | 10:40 AM
98 shadow's Avatar
that's what I was hoping thanks
Old May 12, 2020 | 12:39 PM
Make sure you don’t break any of the vacuum lines during removal. They are quick connect and you may need a tool for them.
Crandell
Mar 21, 2019 11:44 PM
fredd60
Mar 10, 2019 09:01 PM
powerhouse
Oct 17, 2014 10:41 AM
nairnman
Dec 20, 2010 08:53 AM
