Easy air box removal modification.
Old Jun 18, 2022 | 02:24 AM
Pistnbroke's Avatar
Default Easy air box removal modification.
Removing the airbox can if you are not aware end up in breaking the rubber mounting bush ( repairs 100% with superglue)
The correct way is to use a 22mm spanner under the airbox bracket to hold the top of the bush .
However once you have it off you can fit a simple bent bit of metal to hold the top to save using the spanner.
Diagram below ..just leave it in place under the bracket and the jobs easy next time.
The bent down bit holds the nut in place .
Barry_Tucker
Mar 18, 2023 07:36 PM
dsd
May 5, 2017 03:30 PM
JagsteRJX
Dec 15, 2016 01:46 PM
emgun
Mar 23, 2015 09:50 PM
havnfun
17
Mar 22, 2011 10:21 PM
