ECU compatibility
Old Jun 29, 2014 | 07:16 PM
RJ237's Avatar
Default ECU compatibility
I am shopping for a spare ECU for my 97, LJA1410AH, but the nearest I can find is a LJA1410AK. Would the experienced members have an opinion of the compatibility of that unit with the rest of the systems?
Old Jun 29, 2014 | 09:00 PM
test point's Avatar
I have some experience with Ford PCM's from the same era. The different part numbers were only different software loads and would work over several model years and a hundred or more different different loads. My opinion is that the hardware is close enough but you may have to have a dealer or well equipped indy do a software reflash . . . or it might work just fine.
I have a '99 PCM running my '00 302 V8 with very different part numbers and without software update. Not aware of anything that doesn't work.
Old Jun 29, 2014 | 09:05 PM
motorcarman's Avatar
Be aware that the 1997 XK8 in North America did NOT have a KTM so no key transponders were used. The 1998MY> used the KTM and immobilizer setup.
I don't know if the ECMs are compatible?????
Anyone tried swapping????
bob gauff
Old Jun 30, 2014 | 03:45 PM
RJ237's Avatar
motorman et al, I checked a friends' 97 today, and he has a LJA1410 AK and no key transponder, so that unit will probably work.
But this afternoon I located an exact match LJA1410AH and ordered that. Bank interest is zip, so this is probably a better investment. Thanks again for your assistance.
Bcrary3
Sep 12, 2021 05:41 AM
King Charles
Oct 16, 2015 01:25 AM
Johncy2000
Oct 2, 2015 01:05 AM
Wayne Enticott
Sep 29, 2015 08:55 AM
