EGR delete
Old Jul 29, 2014 | 04:46 AM
Krajcok's Avatar
Default EGR delete
Did anyone try to delete EGR by placing steel plate between EGR duct and intake elbow? Is it doable with no engine faults or should I forget about EGR deleting with no software mods?
Old Jul 29, 2014 | 07:02 AM
kreyszig's Avatar
pretty sure a few people have re-routed the breather tubes on the 4.0L to a catch-can (or atmosphere), I'm not one of them though.
Slightly different system on the 4.2s I think.
Old Jul 29, 2014 | 08:34 AM
ccfulton's Avatar
Removing the actuator will likely cause a code because the ECU expects it to be there.
Just inserting a plate between the pipe and the intake elbow might cause a code. The ECU knows when the EGR valve is open (it actually can open varying amounts) and uses the O2 sensors as feedback so it may determine that something is wrong.
I guess my question would be why bother?
Old Jul 29, 2014 | 09:59 AM
Krajcok's Avatar
I'm during the process of adapting Kenne Bell 2.2 and designing new intake elbow, so there is great oportunity to delete EGR, which, together with breather is responsible for all that exhaust junk in SC lobes, intake, IC radiators, etc.
Old Jul 29, 2014 | 10:16 AM
The Coupe's Avatar
I don't know the point of changeover, but on the early cars (like mine), it's possible to put blanking plates at the exhaust manifold outlet and the EGR inlet without the ECM throwing a code. The EGR itself does have to be in place and connected, however, I've been told. I've had blanking plates installed for a few years now, no codes and nice to have the exhaust junk going where it belongs...through the exhaust.
At some point, a sensor was added on later cars that will detect a lack of vacuum in the EGR if the blanking plates are installed, and a code will be generated.
Old Jul 29, 2014 | 10:32 AM
JgaXkr's Avatar
The early 1997 cars had egr, it was later deleted with a software upgrade. The XKR in the US has egr & a map sensor. If you blank off the manifold you need to run the pipe to allow the map sensor to detect the valve opening.
Old Jul 29, 2014 | 02:14 PM
ccfulton's Avatar
I'd say the breather is most of it. When I put the twin screw on I added a catch can on the part load side and it catches some nasty stuff.
In the last 10k miles, I haven't noticed any junk in the intake from the EGR alone.
But, if you want to do it, sounds like it can be done if you use the method JgaXkr describes.
Old Jul 29, 2014 | 03:41 PM
Krajcok's Avatar
Have a look at attached fotos, please. 90% of junk comes from EGR flange.
Old Jul 29, 2014 | 05:13 PM
ccfulton's Avatar
I see the picture and can say that mine looked very similar when I took it apart.
I only know my own experience with having the EGR connected and the breather filtered so that there is not the coating of oil to be cooked on by the hot exhaust gas.
revauto
Sep 17, 2020 03:50 PM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
