electric antenna
Old Oct 27, 2009 | 03:33 PM
jaysto's Avatar
Angry electric antenna
antenna sticks , does not raise fully ....can anyone offer any advice on what lubricant to use
Old Oct 27, 2009 | 04:13 PM
Gus's Avatar
Gus
This is a topic that can go on for day! You can do a search and see why or you can use wd40. It displaces water, lubricates and cleans. Spray the antenna, operate it and then wipe it dry with a clean cloth from the base to the tip (to avoid pushing dirt into the layers) and then do it again. If your antenna does not operate properly after 2 tries look into repair or replacement.
Old Oct 27, 2009 | 04:28 PM
H20boy's Avatar
if not simply dirtied up, either one of the sections is bent, or the little teeth on the riser-thingy is damaged. Replacement is pretty simple also.
Old Oct 27, 2009 | 07:13 PM
Kevin D's Avatar
Smile OH, please don't get that started again! LOL!
Clean Antenna, a new band!
Old Oct 27, 2009 | 07:33 PM
hlgeorge's Avatar
Most likely the plastic gear cord is damaged. Replacement is easy if it has not broken off inside the motor as mine was. I had to remove the motor and take it apart to retrieve the broken piece.
oldjaglover
Dec 25, 2024 04:33 PM
philwarner
Jan 31, 2016 09:36 AM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
