Electric gremlins
Old Nov 16, 2018 | 06:52 PM
Felipe Pr's Avatar
Default Electric gremlins
Hi all, today the most estrange thing happen to my 97 XK8. The car was parked in the garage. All of a sudden the horn started honking, lights and wipers on, tried to override with the key and fob to no avail until finally battery exhausted. The car is not used frequently. Any ideas???
Old Nov 16, 2018 | 08:08 PM
giandanielxk8's Avatar
Saludos Felipe! Espero que te encuentres bien! Me pasó algo similar con mi ‘04.
Jump start it, then check to see if any doors show up as open when they are shut. In my case, the passenger door was showing open and it was activating the alarm. It was the door latch microswitch.
Si te resulta que es eso, es una reparación sencilla. Me avisas y te digo donde puedes conseguir un reemplazo y las instrucciones para efectuarlo.
Old Nov 17, 2018 | 07:40 AM
Felipe Pr's Avatar
Saludos Giandaniel, thanks for your suggestion. I'll be not able to work on it today but will try in the morning, will let you know how it goes, thanks.
Old Nov 17, 2018 | 07:59 AM
frankc's Avatar
Battery! When its going you have all sorts of weird symptoms. I found that out first hand.
Old Nov 17, 2018 | 08:16 AM
JimmyL's Avatar
Agree with frankc about the battery. But, something similar happened to me once when I stuffed the key fob in my pocket with a bunch of other things and the alarm and lights started going off. I guess the buttons got pushed accidentally.
Old Nov 17, 2018 | 06:46 PM
michaelh's Avatar
Originally Posted by frankc
Battery!
That was my first thought too - especially if the car isn't used much. Do you keep it on a battery tender?
Old Nov 23, 2018 | 06:59 PM
Felipe Pr's Avatar
Battery, it was the battery. That one was a Bosch bought at Pep Boys two years ago with a three years warranty. Went to Pep Boys, they tested it, found it failed and gave me a new one at no cost. Thanks to all that gave me their feedback.
Old Nov 24, 2018 | 12:25 AM
I'm glad it was an easy fix Felipe!
Old Nov 24, 2018 | 04:42 AM
frankc's Avatar
Thumbs up
Thats the thing about these forums we are 4034 miles apart yet I was able to pass on my thoughts, along with others of course, and help you solve your problem. Its happened more than once or twice in reverse too. The world if definitely getting smaller!
Glad you sorted it in the end.
Old Nov 24, 2018 | 09:27 AM
Brutal's Avatar
Battery, once it gets too low around low 11 volts it wakes up the car then starts all kinds of issues with modules like wiper, alarm etc. Replace the battery and keep it on a trickle/float charger so it has full power all the time
Old Nov 26, 2018 | 08:47 AM
Felipe Pr's Avatar
WTF!!! Did it again today!!! With the new battery!!! Disconnected the battery, did a hard reset, connected it again and continue to happen. Now the battery is disconnected, if I connect it again happens again, started the engine and runs rough, with the honking, wipers and lights on, and the top trying to open, no codes, any ideas???
Old Nov 26, 2018 | 09:00 AM
Brutal's Avatar
You may have a permanent drain that is running the new battery down and doing the same. You need a dvom meter to monitor the battery and any battery drains. Im sure there are how to's in the tech section or somewhere around here. Thats were i would start at this point to verify
Old Nov 26, 2018 | 09:20 AM
RJ237's Avatar
ECU problem? It's a 97.
Old Nov 26, 2018 | 10:06 AM
Felipe Pr's Avatar
Ok, connected the battery again a few minutes ago and everything was perfect again??? Started the car, engine running smooth as always, lights, wipers, a/c, top, windows, radio, everything working as it should. WTF??? Driving me crazy!!!
Old Nov 27, 2018 | 05:17 AM
frankc's Avatar
Id bet a bar of chocolate that its a bad earth. Remove all your connections. Glass paper them put them back on tight. Dont forget the Earth Strap under the car. Just follow the major connection from the battery and remove, clean, and refix tight. Probably explains it appeared fixed when you replaced the battery, which I still think was a good move.
I once had an embarrassing incident with this. When I put my foot on the brake the horn blew. I got some dirty looks in traffic lines.
Old Nov 28, 2018 | 04:14 AM
Reminds me of a Disney movie, Big Fat Liar, where they have a saphire blue XK8 convertible that the child protagonist, portrayed by Frankie Muñiz, rewires as a revenge on the owner. As a result, everytime the driver pressed on the breaks, the horn blew. When he pressed the gas pedal, the wipers went on, etc. Somehow this affected the XK8s breaking performance and to the point it pushed a monster truck’s rear tires at a stoplight. In retribution, the truck driver crushed the Jag.
Old Nov 28, 2018 | 05:35 AM
Not surprised it's crying out for attention. It's LONELY sitting in the garage.
aholbro1
Dec 14, 2011 09:29 PM
brdave
Sep 30, 2011 11:39 AM
mick58
XJ40 ( XJ81 )
Feb 7, 2011 04:36 PM
med
Jul 18, 2010 05:28 AM
