Electric problems solved
Old Aug 6, 2024 | 08:51 PM
Thebirdmam59's Avatar
Default Electric problems solved
Hi all, I'm new at this Jag stuff,but accidentally figured out my problems with the electrical problems. I was having issues with the hood as they call it in the u k Canadians probably say the roof or soft top. Ha. Well I had this fault code telling me that the hood was not latched and the back windows would not close. I was led to believe it was the relays as such I wou manually retract or close the back windows. Untill one day I noticed some wirering hanging down under the glove compartment. I looked around under the dash to see if anything was unplugged nothing seemed out of place except I did see a strapping that fell to the floor and so I stuffed everything back up into place. I then noticed no fault code's so I thought well I will put back the window relays and lo and behold it's all been working well since. No fault code's and even the rear view mirror works now at night properly.
I only now have to work out my head light issue on the passenger side no low beam any suggestions what to look for.?
James
Old Aug 6, 2024 | 10:57 PM
tigerking's Avatar
congrats on solving the electrical gremlins! Those can be so frustrating. for the headlight, maybe try swapping the bulbs from left to right? if the problem moves, it's probably just a burnt-out bulb. if not, could be wiring or the headlight assembly itself.
Old Aug 7, 2024 | 03:50 AM
Redjags's Avatar
Make sure that the access panel is still in place on the wheel well liner. Mine was missing when I bought the car and moisture and dirt had worked its way onto the back of the headlight and may have caused the failure. I got a replacement panel from AutoReserve in the UK, fitted a new lamp, cleaned the connectors and all was good.
Old Aug 8, 2024 | 06:04 AM
I Did buy a new one 100 bucks later to discover it wasn't the bulb. I should have known that as there was no power to the hot dude of the fuse. I will dig in further wish I had a wiring diagram a repair manual sure would come in handy.eh.
Old Aug 8, 2024 | 06:05 AM
Oh yes there was one and I made sure it went back.thanks
Old Aug 8, 2024 | 09:05 AM
bladerunner919's Avatar
They're not difficult to find - look in the stickys.
Old Aug 8, 2024 | 12:44 PM
Gonville's Avatar
well done,,,elec is usually not easy
yorkieboy
Mar 16, 2024 05:37 PM
Sherri H
Feb 27, 2023 06:29 PM
Kenny Locke
Jul 7, 2019 02:00 PM
AC0FC
Jun 24, 2018 09:57 PM
Jsnyder0828
May 19, 2015 11:19 PM
