Electrical ESP
Old Sep 14, 2010 | 12:41 PM
rweber's Avatar
Default Electrical ESP
I have tried to replace my OEM high beam light bulbs with a set of aftermarket blue bulbs of higher wattage. After removing the OEM bulbs and replacing them (to the horrific distress inflicted on my hands) with the new bulbs, they didn't work!!!!! I removed the bulbs and confirmed that they functioned in my truck. I put the old bulbs back in (ouch, wimmper, cry) and they were just fine. So, does the Jaguar know when you fiddle with it, does it have a soul? Can it be tricked?
Old Sep 14, 2010 | 09:52 PM
DaleD's Avatar
From: Marin County, CA, USA - Just north of San Francisco
Here we are again - am I the only forum member trying to keep my beauty original?
These things were designed and built as very unified machines - and left alone, people tell me that they are very, very dependble (forum experience not withstanding.)
I'm all for "fixing" the tensioners, the water pump/thermostat, and hydraulic top pressure known weaknesses, etc., but why are we tempting fate (and upsetting the computers that run the systems) with cosmetic alterations.
I love my car - just the way it is! DaleD
Old Sep 14, 2010 | 11:17 PM
JenniSummers's Avatar
I think it is the ghost of Sir Wm Lyons who does not like us modifying his cars. I swear he was haunting my XJ6 for a while. My car would unexpectedly lock itself and roll up the windows. It did it most when I was driving it, but once while it was in my driveway with the keys in it. I finally figured out that it only did it on really hot days and when the sun was hitting directly on the drivers door. I lived in Palm Springs at the time, so there were a lot of hot days. It seems that the sun was heating up the switch just enough that it was activating it like you had the key in the door.
Old Sep 15, 2010 | 06:16 AM
rweber's Avatar
I designed and built my house because I don't like cookie cutter motif. If Mozart felt that way there would be only one sonata, Ford did feel that way--good grief!
Old Sep 15, 2010 | 06:27 AM
rweber's Avatar
And I'm willing to bet Sir Wm Lyons would love the effect of the ghostly green neon glow tubes under the car. At night it looks like it's floating on a cloud ofKryptonite. Lana Lane watch out.
Old Sep 15, 2010 | 08:00 AM
WhiteXKR's Avatar
Future collectors will appreciate folks like Dale who kept their cars untouched.
I for one thinks we all should all enjoy these cars in the way that gives us the most satisfaction. Keeping them true is the right way for Dale. I feel, as great as they are, these cars are in many ways a product of corporate compromises, and we should improve on them in ways that please us. Some of us are engineers (in reality or spirit) and love the challenge and satisfaction of making improvements. If we do, we should not be afraid of the complex electronics or 'system' aspect of these cars, but we should be prepared for the occasional surprise.
Old Sep 15, 2010 | 12:55 PM
BurgXK8's Avatar
Uhm, I like my car and all, but I've got no delusions about it ever becoming a collectible when so many (and so many in Carnival Red) were made. Besides, even if it is collectable, I bought it for me, not the next guy. Would love to hear how the headlight mod turns out. It can't be the first time someone wanted to put different bulbs in there.
Old Sep 15, 2010 | 01:09 PM
WhiteXKR's Avatar
Given enough time, just about everything becomes collectible. I am not advocating worrying about the next owner.
The point of my last post is that we each have a different way of enjoying these cars. I just think we should just respect that in each other, whether we keep them stock, add just a few tasteful mods or pimp them out.
Old Sep 15, 2010 | 09:42 PM
DaleD's Avatar
Hey gang - I hope everyone realizes that I am laughing at all of of us in this discussion! Of course, we all buy and admire these vehicles for different reasons - and that our expectations (financial, social, etc.) of ownership is different. However, we are all dedicated - and very serious!
As I read the above, I have to think that the color green described is much like that of Sir Wm Lions as might be compared to the color of an internal bodily fluid thrown up in horror! I hope not! Best, DaleD
Old Sep 15, 2010 | 10:41 PM
Reverend Sam's Avatar
I changed out the high beams in my 2003 with no problem. I used HIR lamps (not HID, there's a difference. google it) and they are much brighter. Perhaps you blew a fuse when replacing the lamps. I's start there. Then put in the originals and see if they work.
Old Sep 16, 2010 | 10:36 AM
rweber's Avatar
no did not blow a fuse, old bulbs worked fine. These lamps are HID but they draw only 35 watts instead of 65 watts and the car may sence a open circuit. The other thing may be that the ballast is kaput, I only tried a different bulb not a different ballast. I looked at the HIR bulbs, but they are only available with 90 degree bases, the XK uses straight bases. Oh sure thay can be fitted but it destroys the back of your hands doing it. Now maybe if I had a backseat midget, hmmmm.
To answer some other peoples concerns, changing light bulbs has nothing to do with keeping the car original, even HID's don't change the car because they can be unpluged and replaced with 9005's at will.
Old Sep 16, 2010 | 11:24 PM
It was a little tricky getting the 90 degree HIR bulbs to fit, but it's doable. The problem with HID high beams is that HIDs take a minute or two to warm up to full brightness. Usually high beams are on intermittently because of oncoming traffic and they never get up to full brightness before you have to dim them again.
Having said that, if you think the ballast is bad just wire it directly to the battery and see if the bulb lights up.
Old Sep 17, 2010 | 09:18 AM
rweber's Avatar
I'm going to wire it directly to my battery charger, I don't think it is smart enough to throw a code. On that note, the car didn't respond to having a light out when the HID was connected, I would think if something was wrong it would have.
bdboyle
Nov 6, 2015 02:07 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
magmedia
Sep 28, 2015 09:49 PM
