ELM327 OBDII reader - how to pair with Torque/Android
Been struggling with this for over an hour now... According to 'Settings', the ELM327 is now paired to my Galaxy II tablet, but the Torque application still says 'No Bluetooth device paired' and nothing works.
Any advice?
Any advice?
Did you get this to work?
I don't have a tablet but my Vgate BlueTooth connector works reliably with my Samsung Galaxy:
I didn't use the setup CD that came with the connector. This is the sequence used:
1. install the Torque Android App on the phone through Google Play
2. plug the connector into the vehicle and startup
3. check connector is powered up
3. allow the App to discover the device
4. enter the default PIN (has to be done every time)
5. wait about 15 seconds for connection
Are you getting the PIN input screen?
Are you sure you've got Bluetooth enabled on your tablet Frog?
Sometimes it's disabled by default until you go into the settings.
And you need at least your ignition on P2, in fact I started the car before trying to connect.
Actually they are different OBD2 devices aren't they?
Mine looks similar to GGG's.
I may have needed a pin initially, but after the first time I just plug the scanner into the car port, start the car, open the Torque app and it auto detects.
Scanner was £22.95 off ebay, and well worth it for real time engine temp alone, plus Torque does lots more like fault code reading and clearing.
HHOBD Bluetooth OBD2 Wireless CAN BUS Scanner Interface Adapter Android Torque | eBay
If GGG is using the free version of Torque, that may explain why he has to enter a pin number each time.
I paid a few pounds for the Torque version with extra functions, either £3 or £5, but well worth it.
I think the cheap "Chinese clone" ELM adapters are a bit hit-and-miss - I had one similar to yours and couldn't get it to work. Sent it back - replacement (identical) worked OK.
I assume you have done the following :
Paired your phone with the ELM adapter (check on the bluetooth menu on the phone to be certain.)
Open "Torque" on your phone and open the OBD2 Adapter Status menu which will tell you whether a) Bluetooth is enabled, b) Connection to adapter is OK, and c) Connection to car's ECU.
If Bluetooth is enabled, but there's no connection to the adapter or the ECU, then your adapter is probably faulty.
Hope this helps.
Hope this helps.
After you finally get the correct code pin number you need to go into your program settings (Torque) and connect it there. Click on 'more', then settings then scroll down to Device and turn it on.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
