Engine Earth Lead Location
Old Mar 1, 2019 | 05:28 PM
DavidYau's Avatar
Default Engine Earth Lead Location
Gents,
I had a bit of an oil leak from the cam shaft covers and am cleaning up the old oil in the engine bay.
As good practise, I was going to check the engine earth/ground connection but can't seem to find it. Part No LBN3740AA looks all shiney braided silver but I can't see it anywhere.
If anyone is under the bonnet this weekend, can you please take a pic to show me where this is?
Old Mar 1, 2019 | 06:34 PM
kstevusa's Avatar
David, the Braided Steel Strap runs from the X-Member near the RF lower control arm area up to the bell housing on the right side underneath on the XK8. I believe its the same on the 5HP25 and 6HP26 Cars. No pic but I've cleaned and tightened this ground also.
Old Mar 2, 2019 | 04:27 AM
frankc's Avatar
Here you go.......
Franks tip. Make sure you REALLY clean the surfaces its going on. My engine would not start and I had to have the car towed to a garage as the mechanic just bolted the new earth strap on without cleaning the mounting surface. Above is the very strap and how it was originally fitted.
Take a look at the hassle this simple fault caused me. Click here please.
Old Mar 2, 2019 | 04:28 AM
RaceDiagnostics's Avatar
There are a few pics here.
https://www.jaguarforums.com/forum/x...h-strap-95581/
Old Mar 2, 2019 | 06:16 AM
DavidYau's Avatar
Default A picture tells a thousand words
photos are brilliant. That’s what the forum is all about!
Ubad2
Feb 18, 2018 11:01 AM
bobg
Nov 14, 2017 11:07 AM
Some Day, Some Day
May 7, 2017 07:28 AM
FireCrow
Sep 27, 2012 04:16 PM
hlgeorge
May 5, 2010 08:29 PM
