engine management light
Old May 20, 2012 | 12:52 PM
dennisw's Avatar
Default engine management light
been out for sunday lunch..started car.eml light on.turned engine off tried few timed still on..drove home with light on..car drove normal but I was worried.checked with code reader came up ..missfire on cylender one..think the code was 0301..cant remember..deleted code..light now out..is this something brewing?help plese..
Old May 20, 2012 | 02:35 PM
MRomanik's Avatar
Veteran: Air Force
I got a P0302 (misfire cylinder 2) along with other codes about a week ago. I found a small amount of oil in the spark plug hole. I cleaned it out and cleaned the plug. I cleared the codes.They haven't come back yet. I suspect the cam cover gasket is leaking.
Old May 20, 2012 | 02:49 PM
dennisw's Avatar
thanks for your reply..think mine was just a fluke..hope so
Old May 20, 2012 | 05:42 PM
Could be from leaking oil as suggested by MRomanik or possibly a coil on the way out.
If the same code repeats, clear again and switch Cylinder 1 coil with Cylinder 2. If you subsequently get a misfire code Cylinder 2, that will confirm the coil is dying.
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
XFR_Gold
Sep 2, 2015 12:24 PM
TC Johnson
Sep 2, 2015 09:30 AM
