engine misfire
Old Mar 18, 2014 | 11:34 AM
perrymik's Avatar
Default engine misfire
Can someone help,
Last night during normal cruise the check engine light came on with poor engine performance message.
I nursed the car back home and plugged in a code reader this morning, the following codes came up
Under stored section :
P0305, p1314,1316
Under pending:
P0305, p1314, p1316
After reset of these codes, check engine light went out and the following code came up
P0305, P1316
I assumed 1314 refers to misfire rate catalyst damage fault - bank 2
Does it means the catalyst converter is done?
Any idea?
Old Mar 18, 2014 | 02:24 PM
mike66's Avatar
Probably a coil. What is your model year? It matters on telling which cylinder to attack. Your converter is probably fine.
Old Mar 18, 2014 | 02:43 PM
perrymik's Avatar
Thx for the quick respond
its 1997 XK8
Old Mar 18, 2014 | 03:01 PM
RJ237's Avatar
#5 is the first cylinder on the left (drivers US) bank.
Old Mar 18, 2014 | 03:22 PM
perrymik's Avatar
got it first cylinder driver side,
any idea where I can purchase a coil?
Old Mar 18, 2014 | 03:26 PM
mike66's Avatar
First, swap with another cyl and see if the problem moves before you buy another coil.
http://www.ebay.com/itm/261015895977...witem=&vxp=mtr if you have the 4-pin coil.
Old Mar 18, 2014 | 03:57 PM
perrymik's Avatar
good point,
I will swap and report back,
in the meantime many thx
mike
Old Mar 20, 2014 | 08:20 PM
H20boy's Avatar
Good advice mike, you've got this one
Old Mar 28, 2014 | 10:46 PM
perrymik's Avatar
Thank you all for your help,
I did order the ignition coil, i installed it today and the problem was resolved.
Thank you again
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
