engine misfire
Can someone help,
Last night during normal cruise the check engine light came on with poor engine performance message.
I nursed the car back home and plugged in a code reader this morning, the following codes came up
Under stored section :
P0305, p1314,1316
Under pending:
P0305, p1314, p1316
After reset of these codes, check engine light went out and the following code came up
P0305, P1316
I assumed 1314 refers to misfire rate catalyst damage fault - bank 2
Does it means the catalyst converter is done?
Any idea?
P0305, p1314,1316
Under pending:
P0305, p1314, p1316
P0305, P1316
Any idea?
First, swap with another cyl and see if the problem moves before you buy another coil.
http://www.ebay.com/itm/261015895977...witem=&vxp=mtr if you have the 4-pin coil.
OkieTim
Sep 8, 2015 04:48 PM
