engine noise sucking sound varies with RPM
Old Mar 18, 2015 | 12:23 PM
billat3800ft's Avatar
Default engine noise sucking sound varies with RPM
99 XK8 I have an engine noise that sounds like a radiator cap releasing pressure but its coming from the center of the engine and it varies with the RPM and is like a vacuum leak but there are no engine codes anyone experience this?
Old Mar 18, 2015 | 04:56 PM
Default vacuum noise solved
I had just replaced the vacuum lines with regular vacuum hose and it was collapsing due to the strong vacuum and now it must be replaced with a more rigid vacuum hose. Thats why jaguar used plastic hose but that becomes brittle due to heat and leaks.
D.K
Dec 10, 2023 02:05 AM
PMKimpton
Aug 3, 2019 08:22 PM
OkieTim
Sep 2, 2015 12:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
innzane
Sep 2, 2015 10:08 AM
