Is this the engine number?
I'm pretty sure I have a 1998 XK8 4.0 with an AJ26 - so I thought the engine number should be by the thermostat housing. But I can't see anything there, and I have looked a lot! Should there be a flattened area with the stamped number? I can't see anything like that...
I found this stamped down by the steering column, poked my phone up to see it clearly - it seems to say:
*SRLNJ*BBBC*
*22211122*VVVVV*
Is that an engine number? I've also read this is the bearings used in the motor?
