Engine Number?
Old Jan 30, 2022 | 08:54 PM
Dickiederson's Avatar
Default Engine Number?
Is this the engine number?
I'm pretty sure I have a 1998 XK8 4.0 with an AJ26 - so I thought the engine number should be by the thermostat housing. But I can't see anything there, and I have looked a lot! Should there be a flattened area with the stamped number? I can't see anything like that...
I found this stamped down by the steering column, poked my phone up to see it clearly - it seems to say:
*SRLNJ*BBBC*
*22211122*VVVVV*
Is that an engine number? I've also read this is the bearings used in the motor?
Old Jan 30, 2022 | 11:08 PM
srpope80's Avatar
A '98, as I recall should be by the thermostat housing. I had to use a little flex camera attached to my phone to view it.
On my Silverstone, the engine was manufactured 07/15/2000, the stamping was next to the thermostat housing.
On the same model year XK8, it was on the rib below the numbers you listed but that engine was manufactured 12/08/00.
I'm ASSuming sometime between the two they moved the stamping location.
Old Jan 31, 2022 | 06:03 AM
Robin Smith's Avatar
I have a 98 and my engine number is down by the thermostat housing. I had to do some cleaning down there before I could read it.
Old Jan 31, 2022 | 06:22 AM
michaelh's Avatar
See this post from GGG:
https://www.jaguarforums.com/forum/x...2/#post1948910.
As noted - it's not the easiest thing to see
jaguar1966$
E type ( XK-E )
Feb 10, 2023 09:20 AM
jacopost
Nov 14, 2020 01:18 PM
stevepaa
Feb 9, 2017 09:08 AM
xj8vdp
Sep 11, 2015 11:37 AM
GreenJewel
May 13, 2009 03:00 AM
