Engine removal - rear seal replace-anything else to be done same time?
Old May 10, 2013 | 06:24 PM
vettegood's Avatar
Default Engine removal - rear seal replace-anything else to be done same time?
Hello to all,
My 2001 XKR has 91K and has developed small oil leak in two places.
#1 Main bearing oil seal rear(small drip) and
#2 upper oil pan silicone seal (no drip just moist).
The engine has to be removed to accomplish repairing the 2 leaks.
Thank the lord I have after market warranty, they have already approved 1900.00 for the job.
Mostly Labor cost, about 80 bucks in parts and another 60 in oil, rest is labor.
My question- since the engine will be out of car is there anything else I can or should do based on this?
Anything to transmission,suspension, hoses, lines, clutch, A/C blower motors etc.
Anything to be concerned about with removing and replacing the engine?
Any wisdom for repair/upgrades now rather than later would be very much appreciated.
I am not doing the work, the repair shop is.
Thanks for ideas and suggestions.
Happy Motoring...
Old May 10, 2013 | 06:37 PM
WhiteXKR's Avatar
Looks like a good time to inspect the engine mounts thoroughly for deterioration.
Old May 10, 2013 | 07:08 PM
vettegood's Avatar
Thanks WhiteXKR,
I can always count on you for good info. How many engine mounts are there?
Thanks again.
Happy Motoring...
Old May 10, 2013 | 07:15 PM
WhiteXKR's Avatar
Originally Posted by vettegood
Thanks WhiteXKR,
Thanks again.
Happy Motoring...
Two hydraulic engine mounts and a rear engine/transmission mount.
Old May 11, 2013 | 12:55 AM
avos's Avatar
If you haven't flushed your transmission, this is the time, as you can now suck the oil out of the torque converter (takes a little time, but you can get it all out).
Old May 11, 2013 | 09:41 AM
dsnyder586's Avatar
coolant hoses are a MUST.
BrentGardner
29
Dec 16, 2024 12:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
rusty37
Jun 7, 2016 04:43 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
dpappyp
Aug 27, 2015 06:31 AM
