Engine replacement
Old Oct 17, 2018 | 12:11 AM
MFoncerrada8's Avatar
Default Engine replacement
I need to replace the engine in my 1998 XK8.
It seems that's the AJ26 engine only installed on the 1997-98 XK8 and XJ8
how different is the AJ27 used from 1999-2003 ? Would I be complicating the swap significantly by using an AJ27?
Advice appreciated
Old Oct 17, 2018 | 08:59 AM
motorcarman's Avatar
Old Oct 17, 2018 | 10:24 AM
dsnyder586's Avatar
Answer: Sorta different, definitely complicates. Having done the opoposite surgery I would recommend finding a good AJ26 and just drop it in, otherwise you are looking at swapping a bunch of parts...
davetibbs
May 29, 2024 02:06 AM
sjgh
Jul 31, 2013 08:25 AM
ccbradley1
Nov 9, 2009 08:37 PM
skanoski
Aug 14, 2008 08:49 PM
Mar 23, 2007 01:37 PM
