Engine Runs, no drive.
Old Jan 11, 2026 | 10:12 PM
  #41
brinny's Avatar
Originally Posted by Y2KJag
The 5 speed and the later 6 speed in the N/A cars, both ZF transmissions, do indeed have fill plugs. Otherwise how would one fill the trans? Neither have dipsticks.
dont think the 5 speed does. 6 speed does but its an 02 car, dont think thats 4.2.
Old Jan 12, 2026 | 03:08 AM
  #42
brinny's Avatar
Thanks for the reply, and thanks for taking the time to read the symptoms I was describing, I don't think everyone has!
At no point do you state which gearbox is in the car or which engine.
Old Jan 12, 2026 | 03:09 AM
  #43
bladerunner919's Avatar
Well, how would you fill a 5 speed if there's no fill plug?
Old Jan 12, 2026 | 03:38 AM
  #44
michaelh's Avatar
For the avoidance of doubt, here's a snip I borrowed from the CTSC:
It's strategically located near the exhaust so as to keep your hands warm during the fill process
Old Jan 12, 2026 | 05:04 AM
  #45
RichardS's Avatar
The 5 speed, 6 speed and 8 speed ZF gearboxes all have fill / level plugs as I know from draining and filling all of them.
Richard
Old Jan 12, 2026 | 07:10 AM
  #46
brinny's Avatar
Well if you try a 99 4.0 you will need to use the dipstick tube .
Old Jan 12, 2026 | 07:15 AM
  #47
brinny's Avatar
Which box, which model car? That int a 99 xkr box for the avoidance of doubt michael.
Old Jan 12, 2026 | 08:19 AM
  #48
RichardS's Avatar
Are you referring to the Mercedes gearbox rather than the ZF gearbox? All the XK8 models of any year and engine size use a ZF box.
Richard
Old Jan 12, 2026 | 08:54 AM
  #49
brinny's Avatar
Yes mate mercedes. Dont know about xk8 and poster didnt provide any details. If he hasnt bothered doing any preventative maintence at 135k then shouldnt be surprised if its gone bang. An expensive missed fluid change by the sounds of it.
Old Jan 12, 2026 | 09:11 AM
  #50
michaelh's Avatar
No, it's a ZF 5HP24 transmission, brinny, which is what the dialogue is about & the OP has in his 2002 XK8...
Old Jan 12, 2026 | 09:33 AM
  #51
brinny's Avatar
Yes, took a lot of dialogue to establish. No matter, sounds like its full of shreade trash now!
Old Jan 12, 2026 | 09:36 AM
  #52
brinny's Avatar
could be a 6speed also michael🤣🤣🤣
Old Jan 13, 2026 | 03:50 AM
  #53
Jag_Willi's Avatar
Hello,
To my knowledge, the switch to the 4.2L and 6G transmission was in 2020. Therefore, it could be a 4L or 4.2L engine, meaning it could also be a 5G or 6G automatic. The information about the initial registration in 2002 is too vague. In the case of the XK8, it is definitely a ZF transmission, as, to my knowledge, the Mercedes transmission was only installed in the XKR in conjunction with the 5G automatic transmission.
Best regards, Willi
Old Jan 13, 2026 | 04:26 AM
  #54
brinny's Avatar
Originally Posted by Jag_Willi
Hello,
Best regards, Willi
hi willi, i agree the posters imformation was vague however the mistake with the merced3s box is mine as i have only had xkrs. My 99 is the famous sealed for life version while my 03 has the serviceable unit.
Old Jan 13, 2026 | 04:45 AM
  #55
You don't have any XK8 or XKR listed in your sig, so we didn't know what car you have.
Old Jan 13, 2026 | 05:42 AM
  #56
brinny's Avatar
ive tried to update it a couple of times with no success. I did state 99 xkr in the posts.
Old Feb 6, 2026 | 10:52 AM
  #57
Gnorty's Avatar
Update -
Gearbox had input shaft broken. Fluid levels were fine, and the fluid was actually in pretty good shape.
Low milage used box fitted by a local guy.
Car ran like absolute **** when I picked it up!
Voltage up to 17V on the dash gauge at over 2k rpm , instrument lights going off. Misfiring horribly. Warning codes for gearbox, instrument cluster, O2 sensor, ABS, probably more!
Many codes voltage related, so first ting, replaced the alternator.
Voltage now 13V, most codes clear. O2 sensor code, bad idling and awful misfire when up to temp still remaining.
O2 sensor replaced, now idling nicely. No coces.
Took it out for a short drive. Initially fine, but degenerating badly when up to temp. No codes though, and gearbox at least felt good.
Popped coil off under the reservoir, and sure enough, full of coolant. All 4 cylinders as it turned out.
cleared water from the wells and put it all back together, and now running nice. Idles good, revs well at running temperature.
So looking good. Still haven't driven it in anger.
A bit pissed off that it seems the mechanic seems to have flooded the spark plug wells somehow (probably removed the reservoir for access), and strange the alternator failed exactly as he was working on it, but happy the car is recovered!
Thanks for all the help leading up to this. I was certainly on the brink of sending it to the crusher!
Old Feb 6, 2026 | 11:17 AM
  #58
michaelh's Avatar
Thanks for the update and glad you finally got there
It's the first time I've read of a broken input shaft, although the alternator failure is more common. I had exactly the same symptoms.
Old Feb 6, 2026 | 11:24 AM
  #59
brinny's Avatar
Nice one. Glad it worked out.
Old Feb 6, 2026 | 04:26 PM
  #60
Gnorty's Avatar
Same, although with hindsight the symptoms were there (TC spinning, zero input speed on the gearbox through OBD) and somebody above did mention it as a possibilty
17V on the dash VM was the big clue, all the other symptoms make sense from there. I am really glad I noticed the voltage being high, because I would never have sorted through the list without such a huge pointer!
MuscatCat
Jan 17, 2023 03:00 PM
fried_hippies
Jun 30, 2020 06:18 AM
mrdiggler
Feb 3, 2020 09:18 AM
Dazzler
Dec 17, 2014 08:00 AM
mrdobsie
May 8, 2011 01:44 PM
