Engine Serial Number Location
I did a search of the forum and did not find anything so if the answer is out there I apologize...
Does anyone have a picture or diagram of where the engine serial number is located?
Thanks in advance!
Thanks in advance!
The easiest place to read the engine serial number is on the computer terminal at you local Jaguar dealer with the VIN as input. It is stamped on a milled area near the water pump but I defy you to read it.
KarimPA
Sep 3, 2015 07:32 PM
.........but if you're determined:
