engine vibration
Old Sep 22, 2008 | 01:57 PM
wheeble's Avatar
Default RE: engine vibration
Not much to go on. I would disconnect the battery for 20 minutes then start and hook up a obdii, see what codes if any come up.
Too many variables to give any suggestions for mild eng vibration.
But just stabbing in the dark, I'd say a fouled plug or bad ign coil at one of the cylinders.
Old Sep 22, 2008 | 02:00 PM
Joe_04_XJ8's Avatar
It may have a dirty throttle body, or an air intake leak.
Old Sep 22, 2008 | 02:28 PM
H20boy's Avatar
My first guess would be years of using cheap gas and the fuel system is just bogged down. If you're into spending money, let the dealer give it a good 'flushing' per se, and clean the injectors, throttle body, etc. Plugs may be fouled also, but hard to tell w/o physical examination. Air intake as mentioned by Joe above could also be a variable.
You sure you wanted it back in this condition?
Old Sep 23, 2008 | 12:33 AM
Joe_04_XJ8's Avatar
H20boy, I think you are spot on about the injectors. If it were mine I would run a can of that cleaner through it that you guys think highly of, with a tank of gas. What is the name of it? Also there are some good instructions on here on how to clean a throttle body. Do a search and you will find them. The main thing to remember is to use a mild cleaner that is made for this job, so you don't damage the thin coating on the inside. You didn't say how many miles it has. If you think it might be plugs pull one, this will give you a good idea if they need changed.
Old Sep 23, 2008 | 02:07 PM
hlgeorge's Avatar
I had an intermittant misfire that a can of BG-44K cleared up. It is best to use this cleaner on a trip and not let it sit in the tank for a long period of time. It needs a good hot continuous flow through the injectors to clean them properly. Also cleans spark plug deposits. A weak coil could also cause the car to shake, but this usually sets off an OBD2 code.
SD96XJ6L
Jan 12, 2022 04:30 AM
GordoCatCar
Jan 2, 2017 01:10 PM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
