Er after 2000 XK8 Instrument Cluster Replacement
Old May 10, 2023 | 06:53 AM
erjent's Avatar
Default Er after 2000 XK8 Instrument Cluster Replacement
Hi All,
I have been using a replacement IC (199,000 miles) for the past few months while shaking out issues on my 2000 XK8 convertible. It has been running well. I am getting ready to register the vehicle and put in the original IC (65,000 mile) with a bad Gas Gauge. I did a hard reset, and now when starting, I get an Er on the Climate Control panel which does go away, and 10 chirps. I am also showing a errant Low Coolant warning, Low Oil Pressure, Battery Not Charging and Red and amber lights and Check Engine. Any thoughts or suggestions?
Old May 10, 2023 | 08:24 AM
motorcarman's Avatar
Read the TSB and you can also interrogate the Climate Control Panel.
Old May 10, 2023 | 12:57 PM
erjent's Avatar
Thank you!
Old May 10, 2023 | 02:02 PM
Also check the Climate Control.
Old May 10, 2023 | 07:19 PM
erjent's Avatar
Much thanks!
erjent
Jan 7, 2026 10:06 AM
slick.one
Apr 20, 2024 08:28 PM
jsnyder2013
Oct 7, 2016 12:54 PM
cat_as_trophy
Feb 9, 2016 03:41 AM
webbeing
Aug 23, 2014 01:30 AM
