Error codes P0207 & P0307
Old Dec 7, 2024 | 07:53 PM
Salmonri's Avatar
Default Error codes P0207 & P0307
I have a 2005 XK8, 4.2 and during this cold spell l’m getting intermittent codes P0207 & P307 combined with rough running and reduced performance. Some times it will occur during first start of the day and other times it will occur on start up following a 40 minute ride where I experienced no performance issues. Any suggestions?
Old Dec 8, 2024 | 06:06 AM
bladerunner919's Avatar
Swap the coil pack from cylinder 7 with a different one and see if the error moves with the coil pack. If so, you need a coil pack, if not, further investigation of no7 would be needed. When you go to swap it you may well find that the plug well is full of oil from a leaking cam cover gasket, which may be the cause of the issue.
Old Dec 8, 2024 | 07:45 AM
Salmonri's Avatar
Thanks…. I will try that test
Old Dec 8, 2024 | 09:24 AM
Don't forget to clear any codes after you do the swap, so that you're not confusing matters with legacy codes.
Old Dec 9, 2024 | 06:17 AM
Salmonri's Avatar
Prior to swapping in coil pack for cylinder 7, I checked the resistance of the fuel injector and I found it to be 36 ohms…directly off the injector pins…. Looks like I have a bad injector
Arsenal01
Oct 12, 2023 06:00 PM
dwh711
Nov 25, 2016 02:49 AM
Kewpie
Feb 22, 2016 10:48 AM
magnum454
May 13, 2014 11:45 AM
carlorner
29
May 27, 2011 03:51 PM
