Evaporative Emission System Leak
Old Jan 24, 2020 | 09:36 AM
JagXK82001's Avatar
Unhappy Evaporative Emission System Leak
Darn code is still with me. I have been trying to resolve this one for months. Changed out the gas cap, that did not help. Found a disconnected pipe on the drivers side charcoal canister at the rear of the car and plugged that back in and cancelled the code with my reader, but alas, it cam back. Traced down the pipe around the filler neck inside the trunk and all looks find. Cleaned out the filer drain to make sure no water was backing up, no change. I do not smell any gas fumes or hear that clicking sound that so many talk about when the cannister purge valve quits functioning, but I guess it could still be that .
I am open for suggestions. I am not a mechanic but enjoy working on cars and have a CEN-TECH OBDII/EOBD Scanner I use to check trouble codes. Any help would be appreciated.
Old Jan 24, 2020 | 09:56 AM
rothwell's Avatar
Did you check this short hose connection on the passenger side? That one gave me a code P0456.
Old Jan 24, 2020 | 10:14 AM
motorcarman's Avatar
You should check the entire system with a 'smoke-machine'.
There are many TSBs (the ones nobody reads) to help with diagnosis.
File Type: pdf
File Type: pdf
Old Jan 24, 2020 | 10:15 AM
And some service action/recalls.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 24, 2020 | 07:14 PM
David Dougherty's Avatar
Default Had a small leak code
For what its worth, had the slight leak code and it2 turned out to be the cannister close valve,
nilosjag
Jul 22, 2025 09:23 PM
hunterpayne
Apr 10, 2019 05:12 PM
nixx
85
Mar 21, 2017 07:15 AM
Spikepaga
Jan 19, 2016 06:20 PM
chtp66
May 26, 2014 06:45 AM
