Failed Block Test
Old Jan 6, 2015 | 06:01 PM
Mykitn's Avatar
Default Failed Block Test
So my wife has a 2003 XK8 with the 4.2 engine. Only has 47,000 miles on it and she probably only put 2000 miles on it this past year. Yesterday she drove about 10 miles and it overheated. No warning lights, No warning gauges, temp gauge was still normal. She pulled over and waited a while and then my son popped the hood and poured a few bottled waters in the cooling system and she drove it to a Midas shop nearby. The guy said he did a block test on it and it failed. Said I had a blown gasket or a cracked block, either way, he said to replace the engine. Would she crack a block that easily? Is there another option? Another test? They said she had two leaks in her cooling system which probably led to the heating problem....
Old Jan 6, 2015 | 06:48 PM
RJ237's Avatar
I don't think a Midas shop is likely to make a correct diagnosis, especially without tearing the engine down. A blown head gasket is almost certain, maybe warped heads also, and yes, a cracked block is possible.
You need to get the car to a qualified mechanic. Hopefully, one of the forum members is in your area and can suggest one. A Jag dealer is just going to repeat the engine replacement diagnosis, probably without looking at it.
Once again we see the need for a proper water temp. gauge like Realgauge. But it's also disturbing that the low coolant light was not on.
When you have time, please visit the new member area and introduce yourself to the forums.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
JWheeler
Nov 22, 2019 08:28 AM
duecedriver
Dec 25, 2015 11:47 AM
Papelione
Sep 21, 2015 06:13 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Richard_gib
Sep 12, 2015 07:08 PM
