Failing to Start - RESOLVED
Old Jun 14, 2018 | 01:48 PM
Louiep's Avatar
Default Failing to Start - RESOLVED
Jaguar, XK8, 1999. Won't start, just a clicking sound when the key is turned in the ignition.
Any suggestions, greatly appreciated.
Last edited by GGG; Jul 5, 2018 at 03:57 AM. Reason: Add "RESOLVED" to thread title
Old Jun 14, 2018 | 01:50 PM
Jon89's Avatar
How old is your battery, and what condition is it in?
Old Jun 15, 2018 | 11:00 AM
Louiep's Avatar
I know the battery is at least 10 years old. Charged and stored after each season. Lights, wipers, etc. all work.
Old Jun 15, 2018 | 11:06 AM
Jon89's Avatar
Regardless of your lights and wipers working, a battery that old is always the first suspect. These cars need massive power to start and run properly, and a ten-year-old battery will not be up to the job. Often times a four or five-year-old battery is too worn out to do the job, especially if the cells have not been consistently topped up with water over the years....
Old Jun 15, 2018 | 03:46 PM
Louiep's Avatar
Local Mechanic believes the battery is good??? He thinks it may be the Starting Motor or Solenoid???
Any idea of where the solenoid is located, would it be on the Starting Motor or a Stand Alone solenoid?
Old Jun 15, 2018 | 06:02 PM
avern1's Avatar
He believes it is good, or did he load test it and it checks out good. The Jaguar will not crank when battery voltage is less than 11.5 volts. Normal is 12.5 to 13 and charging is 13.5 to 14.5.
To answer your question: The starter solenoid is part of the starter and not stand alone. In order to handle the amperage required for starting the system uses a starter relay.
If you know the battery is up to par then swap out a like relay for the starter relay and see if it will crank. If it cranks the relay is bad.
Old Jun 15, 2018 | 08:26 PM
Lady Penelope's Avatar
There will be more then one relay click on key rotation on the X100 and the specific one to put your finger on to feel it is the starter relay .
Old Jul 4, 2018 | 11:33 AM
Louiep's Avatar
Thanks everyone. It was the battery.
prismouk
Jul 18, 2013 08:19 AM
martinvecchio
XJ40 ( XJ81 )
Nov 3, 2009 09:50 AM
qwakwak
Sep 10, 2009 04:32 AM
AGLXTYPE
Jan 11, 2008 11:15 AM
solentblue
Nov 14, 2007 10:15 AM
