Fan xkr 2001 operation
Old Oct 13, 2014 | 07:01 AM
tanngo's Avatar
Default Fan xkr 2001 operation
hot days, hard run. then replace combusible few minutes when I restart fans running on high velicidad few seconds / normal? is the heat generated by not circulating water? Genuine Termostat new / genuine pump water new / dex cool Orange new / spark pug NEW etc... only 20.000 milles . Sorry lenguaje / hablo espaņol /
Old Oct 13, 2014 | 08:44 AM
RJ237's Avatar
I don't think that's a problem. When the engine is shut off there is a lot of residual heat that raises the temperature of the sensor high enough to cause both fans to run on high when restarted.
Old Oct 13, 2014 | 11:33 AM
tanngo's Avatar
I thought the same! I have terror will overheat
Old Oct 13, 2014 | 01:07 PM
RJ237's Avatar
You would be more comfortable if you add a temperature monitor, your gauge is not useful over 185 F. I have a Ultragauge in my XJ6 and switch it to the XK8 when on trips. It plugs in to the OBD2 port and can monitor many engine functions, also has alarm for temp. It is also a code reader.
UltraGauge OBDII Scan tool & Information Center
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
mrplow58
Jan 21, 2024 05:53 AM
skadmiri1
Sep 9, 2015 11:27 AM
1100me
Sep 7, 2015 06:26 AM
