Fans are coming on after driving for 4-5 minutes
Old Aug 1, 2012 | 09:09 AM
randyb's Avatar
Default Fans are coming on after driving for 4-5 minutes
Looks like my thermostat is bad, ho do you replace the thermostat?
01 - xk8
Old Aug 1, 2012 | 09:48 AM
steveinfrance's Avatar
Does this help?
xk coolant flush fill thermostat v1 1 pdf free ebook download from matt.zenfolio.com
Old Aug 1, 2012 | 09:51 AM
RJ237's Avatar
Has your thermostat housing been replaced with the aluminum one yet? If not, you really should consider doing both. Welsh Enterprises sells the aluminum replacement which includes a new thermostat.
Old Aug 1, 2012 | 10:55 AM
Max's Avatar
Max
In addition to the thermostat keep in mind the possibility that the water pump vanes might be plastic and worn down to a nub.
I had this problem a few years back.
Old Aug 1, 2012 | 11:00 AM
Goldlion's Avatar
Say, randyb as others on the Forum have noted this would also be a good time to clean the outer and inner faces of the radiator. With time these can really become impacted with insect matter and road grit and will eventually lead to reduced heat transfer and increased fan run times, regardless of thermostat function.
Old Aug 1, 2012 | 01:10 PM
randyb's Avatar
Thanks all, but I really need to know what is involved in replacing the stat. I have to go on a trip tomorrow and need to do this tonight.
Old Aug 1, 2012 | 02:17 PM
RJ237's Avatar
JagRepair.com - Jaguar Repair Information Resource
Did not understand the urgency. This article is about changing the housing, but you can easily use the pictures to do just the thermostat. It is behind the lower of the two large hoses. You will have to drain some coolant to do this. Then just remove the three bolts the lower hose is clamped on and there is the thermostat. Be careful of breaking the plastic parts, they get brittle with age.
RJ__________________
97 XK8 85K mi
Old Aug 1, 2012 | 02:24 PM
RJ237's Avatar
Not sure if it tells how to drain the radiator. The drain is on the lower right back side, a plastic plug which a large washer can fit in the groove to turn, or maybe 25 cent piece. I do it from below after first removing the plastic shield under the oil filter, 7 mm bolt.
RJ
Old Aug 1, 2012 | 03:27 PM
randyb's Avatar
97 XK8 85K mi
Should have said that first, just trying to do to many things at once.
Old Aug 1, 2012 | 03:37 PM
randyb's Avatar
I will look when I get home, work is blocking this site.
BrentGardner
29
Dec 16, 2024 12:13 AM
1100me
Aug 27, 2020 11:37 PM
Jandreu
Aug 23, 2019 11:37 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
johanasu
Sep 3, 2015 12:39 PM
