Faulty coil testing?
Old Jul 3, 2013 | 02:44 AM
jafari's Avatar
Exclamation Faulty coil testing?
Hello everybody;
I have an intermittent misfire on a few cylinders, but not very often and quite random (I've seen 1,2,3,4 and I think 8 of various occasions). the car is idling rough and occasionally stalls. I don't think its the fuel pump or injectors (both serviced/swapped to no effect) and nice new sparks did not solve the problem.
Could it be faulty coils? Any way to test them (other than swapping around)?
Note: the kitty is due for timing belt swap/upgrade (next month methinks) could this be the cause of misfires and rough idles?
Any thoughts much appreciated.
Old Jul 3, 2013 | 03:12 AM
test point's Avatar
My remote, very remote, analysis based on your classic symptoms of misfires, rough idle and stalls is that you have jumped a tooth on your exhaust cam sprocket on the right side.
Your car doesn't have a timing belt but does potentially have timing chain tensioners that have a terrible history of failing and destroying engines. Jump one tooth you get misfires and rough idle, jump two teeth you bend one or more valves and replace the engine.
I say potentially becaues '02s were supposed to have the upgraded metal tensioners but not all did. Mine did not.
I would not start the car again, not even once, not even to take it for repair, before removing the right valve cover for a look.
After that is verified/resolved the standard method of testing coils is to swap them around.
Old Jul 3, 2013 | 05:49 AM
WhiteXKR's Avatar
I agree that you should take the precaution Test Point has suggested.
If you do determine that the tensioners are OK, then reset the codes once you have a warm engine. Then restart the engine and check immediately to see which cylinder misfire(s) occurs first. The first one or two to register are usually the culprit in a multiple misfire situation.
scooternva
29
Mar 25, 2025 12:45 PM
XJ8JR
26
Aug 8, 2020 09:38 PM
duecedriver
Dec 25, 2015 11:47 AM
hoodun
Oct 2, 2015 10:13 PM
34by151
Sep 6, 2015 05:14 PM
