finished top hydraulics two questions
Old Aug 29, 2014 | 07:19 PM
stevepaa's Avatar
Default finished top hydraulics two questions
First where does the cloth extension with the fir tree clip go?
Second anyone know where this wavy washer with inside diameter 10 mm goes?
Attached Thumbnails finished top hydraulics  two questions-img_4114.jpg   finished top hydraulics  two questions-img_4112.jpg
Old Aug 29, 2014 | 09:20 PM
wolfpck1's Avatar
believe it goes into one of the cover screws for the top hinge. dont remember the wavy washer tho .
Old Aug 30, 2014 | 04:01 AM
johns55's Avatar
If memory serves me, I think the wavy washer goes in the mount at the lower section of the ram (the part the wedges into the black metal box). It helps keep the proper movement and spacing of the ram when the roof goes up and down.
I can't remember where the cloth piece goes, but it does go somewhere
Old Aug 30, 2014 | 06:13 AM
Dr. D's Avatar
I had a hand written note to do the "fir tree fastener" between steps 3 and 4 of Gus'es instructions. (#3 unsnap speaker cover and #4 remove speaker) I can't remember any more specific location.
Since I did not remove the rams and do not remember the wavy washer, I believe that could be where they go.
Old Aug 31, 2014 | 08:44 AM
Glenn Barickman's Avatar
The "fir tree fastener" goes in a hole in the top rear of the speaker cover. I believe, if my memory servers me correctly, which it never does, it also goes through another hole that you will see in the metal tubing to hold the speaker cover in place.
Attached Thumbnails finished top hydraulics  two questions-img_20140831_082911_914.jpg
dsnyder586
Dec 29, 2024 07:39 PM
Harry Dredge
Oct 4, 2024 05:37 PM
Rivguy
Dec 4, 2020 07:55 AM
TXJagR
Jun 20, 2016 01:02 PM
Bret_T
Sep 4, 2015 05:01 PM
