First WOT Run with Eurotoys Upper and Lower Pulleys
Old Jun 9, 2015 | 07:11 PM
Majik Lasers's Avatar
Default First WOT Run with Eurotoys Upper and Lower Pulleys
Just minutes ago I had my first WOT run from 30-110 mph, as I noticed a G37 provoking me in my rear view mirror. It felt like a healthy amount of power and certainly an improvement over stock. The power is felt much faster but seems to plateau as well. Too bad for me that I couldn't pull away from him. I have no way of knowing whether he was at WOT but he was on me like flies on ****...a rather disappointing confrontation. Time to start a twin screw piggy bank I suppose.
Old Jun 10, 2015 | 12:02 AM
SeismicGuy's Avatar
There's always going to be something faster but rarely anything better looking. Enjoy the ride!
Doug
Old Jun 10, 2015 | 11:24 AM
I know I know...and the kitty is certainly a beauty. I still think its a shame that a G37 sedan (a 3812 lb car +2 passengers) with a naturally aspirated V6 (rated 328 hp) can easily keep up with the XKR with far more horsepower (w/ upper and lower pulleys) . I don't fully understand it, but it is what it is and in the short time I've owned the Jag, I've grown more and more fond. I just wish it had more *****...especially in the 0-60 range.
Actually, so far I've had 3 confrontations (I wouldn't call them races) but each time the opposing party drove away more gratified than me; ALL sedans too...300C, Lexus and now a G37 sedan.
Old Jun 10, 2015 | 11:33 AM
brgjag's Avatar
you have a 400hp xkr and cant beat 328 hp car?????? Something wrong with your car?
Old Jun 10, 2015 | 12:59 PM
SeismicGuy's Avatar
The curb weight of the G37 is about 3,600 pounds which is about 400 pounds less than the Jaguar. If you use a 0-60 calculator you will see that weight has a pretty significant on acceleration so I would not be all that surprised to see the G37 keeping up (at least for a while) with the Jaguar.
Doug
Old Jun 10, 2015 | 02:39 PM
brgjag's Avatar
keeping up maybe getting him off the line but even with the 400 lb diff the XKR should get him in quick fashion. I guess we have to assume the other car was STOCK????
Old Jun 10, 2015 | 04:52 PM
I was under the impression that the coupe was 3785 lbs?
Old Jun 10, 2015 | 06:04 PM
SeismicGuy's Avatar
I also think that some of those Asian cars are underrated in terms of horsepower and/or the way they deliver the horsepower. We also have a 2012 Acura TL that is supposed to be about 280HP but feels incredibly responsive. I was in my XKR alongside an Infiniti Q50 recently and that car kept tearing off the line from a red light--same for Lexus GS I have seen and ridden in.
Doug
Old Jun 10, 2015 | 06:09 PM
BobF's Avatar
Has the gas pedal cable been adjusted for WOT.
Old Jun 11, 2015 | 11:54 AM
That's my assumption.
Yes, I adjusted this a week or 2 after I purchased it. That alone made a notable difference, especially in throttle response.
Old Jun 11, 2015 | 12:24 PM
Jag#4's Avatar
Are you in regular mode or Sport mode during these racing adventures?
In normal mode the cat "learns" how you drive. If you normally drive conservatively (I assume you are not always racing) or do not engage in highway speed bursts at 40-60+ often, then it will remap itself to make the best engine management. It does so on the conservative side.
I do daily highway driving, some stretches at 70-80 mph average. In normal mode if I decide to punch it at speed it certainly goes, but it is not dramatic. Change to Sport and even with my NA XK8, it makes a difference.
When working on the blue cat, I occaisionally need to disconnect the battery. I usually do a reset when I connect it back up and the first few times I drive it, it seems like a different car.
Just a thought.
Old Jun 11, 2015 | 03:07 PM
Are you saying that it doesn't learn in sport mode? I'm pretty much always in sport mode...
My daily commute, which is most of my driving, is approx 15 miles (one way) with light traffic, a few stoplights and a 5-6 mile stretch of open road where I might reach 60-65 mph. I really have no choice but to drive conservatively when commuting in even light traffic...so your assumption is correct in that most of my driving is not aggressive or racing.
Old Jun 11, 2015 | 03:34 PM
mrplow58's Avatar
Doug
I view my car as rolling art, and don't really care who is faster than me. I have had some cars that were scary fast, but they weren't JAAAGS, as Jeremy Clarkson would say. There is something about having a vehicle that people lust after, instead of something that makes a lot of noise and smoke......Just my 2 cents. I will never sit on vinyl ever again, just to rattle windows, and scare small children........Be cool.....Mike
Old Jun 11, 2015 | 07:48 PM
Jag#4's Avatar
I think (wiser folk feel free to weigh in here) that sport mode ignores previous driving. Primarily it extends shift points.
Old Jun 11, 2015 | 09:40 PM
Stamford's Avatar
A far as I understand, if you have the gas pedal buried in the carpet, it makes no difference whether you're in Sport mode or not. Happy to be informed otherwise.
Old Jun 11, 2015 | 10:21 PM
Mvirgil's Avatar
Welcome to the serious limitations of the Heaton. With upper and lower pullys your discharge temps will be insane.
Chances are your trans is just fine, But your motor is pulling its maximum amount of timing trying to avoid knocking.
Old Jun 13, 2015 | 07:25 PM
The_Ikon's Avatar
Sounds like you need a intercooler cooler to bring charge down or larger intercooler....
toronadomike
Jan 22, 2026 10:13 PM
Wolfy
May 28, 2024 08:06 AM
08Z06
Oct 24, 2015 05:46 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
rachelstr
Sep 3, 2015 12:59 PM
