fitted new abs pump+module but still not working "97 XK8
Old Apr 8, 2013 | 02:29 PM
chris8spurs's Avatar
Question fitted new abs pump+module but still not working "97 XK8
the computer said that i had traction control and stability failure i replaced the ABS pump and module NOW not only is the computer saying the same thing now the hand break light and the ABS light is staying on .
please advised .
Old Apr 8, 2013 | 02:37 PM
joycesjag's Avatar
Chris I am moving this post to the "General Tech Help" sub forum until we know your MY and model.
Welcome to the forum. You might want to go to the "New Member Area" and properly introduce yourself per forum protocol.
Also please use "UserCP" tab upper left and add your vehicle details so you can help us help you.
Old Apr 8, 2013 | 03:43 PM
It's a '98 XK8, I've added the info to the thread title.
Old Apr 8, 2013 | 03:54 PM
WhiteXKR's Avatar
There are many part number and software variants.
If part number does match, the unit may still need to be reprogrammed to your vehicle by a dealer of an independent Jaguar specialist unless the software versions (on a label under the carpet in your boot) were precisely matched.
Also, are you sure the old one was bad? There are many causes for the traction failure, any many do not involve the pump or electronics. Research here on the forum and on www.jagrepair.com.
toronadomike
Jan 22, 2026 10:13 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
johnnie ryall
Oct 19, 2015 09:44 PM
XFR_Gold
Sep 2, 2015 12:24 PM
TC Johnson
Sep 2, 2015 09:30 AM
