Flashing airbag light
Old Jul 4, 2022 | 11:44 AM
how2's Avatar
Default Flashing airbag light
Hi all have a problem with airbag light flashing 26 times ie 2 long 6 short have looked at a code table there is no code 26 on a 2005 XK8 Thanks for any ideas
Old Jul 5, 2022 | 01:10 PM
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Jul 5, 2022 | 11:24 PM
how2's Avatar
Ok Thank you
Old Jul 6, 2022 | 01:00 AM
Pistnbroke's Avatar
This may help you as its general to all jag air bags
X300 Air Bag Diagnostics for Dummies (2).pdf.
Old Jul 6, 2022 | 01:35 AM
how2's Avatar
Thanks Pistnbroke
Old Jul 7, 2022 | 02:20 AM
Pistnbroke's Avatar
Here you are code 26...All sounds a bit OTT to me ..just check out the passenger seat belt switch and wiring.
Jaguar Xk8 - 26 Airbag Code - 26 SRS Light For Jaguar Xk8 - AirbagCode.com
Old Jul 7, 2022 | 06:07 AM
Jon89's Avatar
Disconnecting the electrical connectors underneath the seat, cleaning them with electrical contact cleaner spray, and then reconnecting them can sometimes clear these pesky airbag codes....
Old Jul 7, 2022 | 02:04 PM
how2's Avatar
Hi Jon 89 Thank you for your advice
Old Jul 10, 2022 | 02:15 AM
Pistnbroke's Avatar
The critical thing with this is that you tell us how you cured it .....you know how2 but we want to know how2 as well.
Old Jul 11, 2022 | 12:16 PM
how2's Avatar
Ok Pistnbroke soon as i know will let you know thats if ican find it
Old Aug 27, 2022 | 12:02 AM
how2's Avatar
Hi Pistnbroke got my 26 flash code sorted it was the occupancy sensor passenger side on the pillar just a bad connection Thanks every one for advice ect
Old Aug 27, 2022 | 12:39 AM
Pistnbroke's Avatar
I thought the seat belt clip had a switch which was used for occupancy? Is there another ? What do you mean on the pillar ? B post ? Photos are always good.
My light is always out as after 10 seconds a timer shorts out the bulb.!!
Old Aug 27, 2022 | 02:23 AM
how2's Avatar
Hi pistnbroke I think the 2005s have a diffrent set up ie there is no seat postion sensor on the bottom rail there are 3 occupancy sensors 1 on the post between windscreen & door my problem . 1 over head were the internal lights are . 1 Just behind the passenger seat After replacing the weight sensor in the passenger seat without cure .Went to see a independent Jag man worked it out in 30 mins Andrew Lindsay Northern Ireland
dav3uk
Jul 20, 2018 07:36 AM
chazaroo
Aug 9, 2013 05:06 PM
newbiegurl
Sep 19, 2012 08:33 AM
