I have a 2002 (MY2003) XKR, and after checking fault codes with my Foxwell OBD reader, I had a fault code come up with "B1410 Front Refrigerant control valve". I assume it is part of the Climate control, if I am right I am still not sure what it is trying to tell me. I have looked through the list of fault codes but am unable to find B1410.
Thanks for the reply, the car is supercharged but I think you may be correct. This is a print out of the fault codes and text, as you can see it also had a P1410, so as you say maybe it got a bit confused with the B1410 code.
P0037 Heated Oxygen Sensor Heater control circuit low (bank 1 sensor 2)
P0480 Cooling fan 1 control circuit
P1410 Air cleaner inlet control circuit P1582 Flight recorder data is stored
B1410 Front refrigerant control valve
I will try it again later and see if it disappears, if not I will undertake a reset and see how that goes.
Many thanks for your help.
