Front Refrigerant control valve
Old Jun 19, 2024 | 12:04 AM
IanDmm's Avatar
Default Front Refrigerant control valve
I have a 2002 (MY2003) XKR, and after checking fault codes with my Foxwell OBD reader, I had a fault code come up with "B1410 Front Refrigerant control valve". I assume it is part of the Climate control, if I am right I am still not sure what it is trying to tell me. I have looked through the list of fault codes but am unable to find B1410.
Any help would be much appreciated
Old Jun 19, 2024 | 10:38 AM
michaelh's Avatar
Your reader is telling you porkies.
As you note, Jaguar doesn't list B1410 for the 4.2L, & most I find for that DTC is 'Driver power window motor circuit failure'
Could it be misreporting a P1410 - as that's specific to the 4.2L supercharged?
Old Jun 19, 2024 | 06:55 PM
IanDmm's Avatar
Thanks for the reply, the car is supercharged but I think you may be correct. This is a print out of the fault codes and text, as you can see it also had a P1410, so as you say maybe it got a bit confused with the B1410 code.
P0037 Heated Oxygen Sensor Heater control circuit low (bank 1 sensor 2)
P0480 Cooling fan 1 control circuit
P1410 Air cleaner inlet control circuit
P1582 Flight recorder data is stored
B1410 Front refrigerant control valve
I will try it again later and see if it disappears, if not I will undertake a reset and see how that goes.
Many thanks for your help.
Adam_W
XF (X260)
Mar 22, 2023 05:29 AM
Flipr78
Dec 26, 2017 03:35 PM
omgimali
Mar 1, 2017 07:48 PM
tony1963
Dec 3, 2016 11:02 AM
Simon.h
Mar 23, 2012 09:33 AM
