Front shock mount replacement and electronic shocks
Old Nov 15, 2025 | 09:13 AM
wojo's Avatar
Default Front shock mount replacement and electronic shocks
My 2003 XK8 all of a sudden is 1/4” lower on the front driver side. I assume it’s the shock mount since I can see debris from it around the shock stud. I watched the utube video and it looks pretty straight forward to replace them. I was thinking I should replace the shocks while it’s apart but was wondering if I have electronic shocks and how to tell. There are no wires attached to the top stud so I’m assuming they are standard. Any input would be appreciated.
Thanks in adavance!
Old Nov 15, 2025 | 12:17 PM
wymjym's Avatar
Must have wires to be electronic!
wj
Old Nov 15, 2025 | 01:09 PM
wojo's Avatar
Thanks!
Old Nov 15, 2025 | 02:37 PM
reach out to @cjd777 or @baxtor for replacement upper mounts - best around and won't have to replace in 3-6 months when other brands fail
Old Nov 16, 2025 | 03:54 AM
pcock111's Avatar
Yes, Wayne/baxtor mounts are the way to go. Personally, if the shocks are still good, I wouldn’t bother changing. Check the bottom mount hasn’t rusted into the shock. If you do change the shock, you will likely run into bother with your white spring packer falling apart. Keep the bits and glue/silicon them back in, as you won’t find the correct tapered replacement is available.
Old Nov 16, 2025 | 10:27 AM
dfbender's Avatar
Agree with keeping the white spring packer. Mine broke apart when upgrading with Wayne’s mounts. I epoxied them and they came out perfect.
davidladewig
Dec 5, 2023 09:43 AM
SeismicGuy
Dec 18, 2022 09:11 PM
dfbender
May 12, 2021 01:16 PM
tjb909
Feb 22, 2017 02:53 PM
gmhspot
May 25, 2015 01:15 PM
